Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 02-16-2008, 10:26   #1 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
el71 imei patch
I need to make el71 imei patch;
I have 2 one of V17 other V41 phones working with orj imei,here is the phones information:
Getting Information:
Model: SIEMENS EL71 17 lg1
Phone is in "Normal Mode". SecurityStatus: "FactoryMode"
IMEI: 358941001102865
HWID: 407
Attention: Charge Accumulator!
Accumulator Voltage: 3614 mV.
Code(05): OTP is Closed for write
Code(09): BootKEY is stored in EEPROM
Code(0D): Keys is stored in BCORE
Code(13): Full access to BFC functions
Code(15): Full mode (not SC)
Code(19): The control is On
Code(1D): 512x blocks presents
EELITE Info: free buffer 185952 bytes, free at all 206240 bytes, free for deleted 206240 bytes.
EEFULL Info: free buffer 192160 bytes, free at all 466432 bytes, free for deleted 204352 bytes.
MAP info: Date: 04/07/06, Variant: A 113, Std-Map/SW: 1/17, D-Map/Prov.: 118/64
Factory (OTP) IMEI: 358941001102865 - matches to flash data.
ESN: 86265044
HASH: EDD6AF52238706EF8876FAC5B5C241C4
BKEY in block 320 = 1C6E0BA24642907E267BF48A645F58D7
SKEY in 5122 = "X" 65143800
Minimum number of firmware: 17.
Bcore ID: 0300, version: main_1.0_V9".
Phone operated: 87579 sec.. Total Talk time: 3498 sec.
FlashID(1) - Manufact. code:0089 (Intel), type: 887E. DisplayID(1,65): Sharp Sharp LHH9168.
Model: SIEMENS EL71 41 lg1
IMEI: 358941001097420
HWID: 407
Accumulator Voltage: 3457 mV.
Code(1F): E71 or EL71sw41(Block 5468)
EELITE Info: free buffer 151200 bytes, free at all 206240 bytes, free for deleted 206240 bytes.
EEFULL Info: free buffer 196832 bytes, free at all 466272 bytes, free for deleted 204192 bytes.
MAP info: Date: 04/07/06, Variant: A 113, Std-Map/SW: 1/41, D-Map/Prov.: 200/245
Factory (OTP) IMEI: 358941001097420 - matches to flash data.
ESN: 7FB8BE51
HASH: A823B2FBFA363E63A7F06634C153CAEA
BKEY in 5468 = "X" 4ADC8650C3CCCFC2A350FBBCDA5D882B
SKEY in 5122 = "
Phone operated: 2340670 sec.. Total Talk time: 2946 sec.
after patch only bızz
where is the wrong? here patch files :
first phone
1 A0D40000.bin orj
el71 1 v41.bin patched
second
2 A0D00000.bin orj
el71 2 v17.bin patched
I think patch is not good ,any help siemens masters pls
regards
Old 02-16-2008, 14:33   #2 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
HWID: 407
ESN: 86265044
HWID: 407
ESN: 7FB8BE51
SKEY in 5122 = "
first phone
1 A0D40000.bin orj
second
2 A0D00000.bin orj
regards
...I'm sorry, but I don't understand. For what you need to patch your phones???
Which program you used to patch this phones? Used V_Klay???
To solve this situation (because I see on EL71 FW41 missing SKEY), use papuautils (v.111b) and recalculate SKEY and BKEY and write in the phone.
dagos
Old 02-16-2008, 14:48   #3 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
....and bellow you have the calculated keys:
SIEMENS EL71 41 lg1
ESN: 86265044
BootKEY: 1C6E0BA24642907E267BF48A645F58D7
SKEY: 65143800
SIEMENS EL71 41 lg1
ESN: 7FB8BE51
BootKEY: 4ADC8650C3CCCFC2A350FBBCDA5D882B
SKEY: 64417246
If don't working after write SKEY and BKEY in the phones, you need to fullflash your phones, use calculated keys and UNLOCK your phones.
dagos
Old 02-16-2008, 15:08   #4 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
dagos
for imei chancing;
skey was calculated also for V41 ;SKEY: 64417246 was ok.
problem is after imei patch phone not work,because patch is not good I think.
I use for patch service software x65 ver1.1b
it works perfect with sl75 ,but el71 not .because after mapping phone not work.
only service mode works.and I check imei was chanced good but patch not ok because normal mode not work .only bızz
I can repair normal mode only with orj imei .I chanceback phone works normal with orj imei.
but I need to chance imei.
thanks your time,regards
Old 02-17-2008, 23:50   #5 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
any idea ? el71 is has more than 1 check imei in eeprom? or in bootloder must be writen again?
how can I patch this ?
siemens masters thanks your opinion (knowledge)
regards
Old 07-08-2008, 18:04   #6 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
regards
hi sir...
did u solve ur pb..? will u change ur el71 imei..?
i have to change it... sw41...
Old 07-08-2008, 18:30   #7 (permalink)
ardagul's Avatar
Member: 7114
Thanks Meter: 51
no,not yet problem is in patch
regards
The Following User Says Thank You to ardagul For This Useful Post:
Old 07-08-2008, 20:58   #8 (permalink)
Member: 809931
can anyonwe help....plssss
need mastercode
imei 35207900-176679-7
Old 07-08-2008, 20:58   #9 (permalink)
Member: 809931
need mastercode
siemans sx1
Old 07-08-2008, 21:09   #10 (permalink)
Member: 201432
Thanks Meter: 38
regards
change flash - from sonyericcson - after that just flash and recalc phone
Old 03-22-2012, 21:06   #11 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hi all..
thread is old but we need it now.. or at least i need it.. i need advices about EL71...
as far as i see this device 2 types Flash ics. one of them is Intel ( 897E_897E ) and the other one is ST ( 2019_2019 ) and i think one of them is not supported with imei operation.. or we need CORRECT adress.. i have 3 x EL71 which has ST flash chip and 17sw... and not supported imei operation.. as the topic starter says phone is not power on after patch.. but main problem is otp area changes according to software.. i mean if i flash it with 06 sw only one adress ( Address= A0840000 Legth= 00040000 ) has OTP area.. if i flash it with 17 sw only one adress ( Address=A0D00000 Legth= 00040000 ) has OTP area.. and the first adress has not the OTP area.. and phone is not power on after these patch files..
anyone has correct adress for this device.? or where is the imei section on flash..? EEFULL or EELITE..?
EEFULL is on the A3F40000 and A3F80000 and
EELITE is on the A0040000
w.b.r.
how to EL71 imei change turkcellgsm x6x and x7x Flashpatching 2 11-02-2008 09:22
new siemens el71 otp patch area adress turkgsmteam S-Gold Based Phones 5 11-03-2007 11:47
deleted thread on dct4 imei patch flash for imei change - where is it dluik Nokia Digital Core Technology 4 ( DCT-4 ) 31 11-21-2004 21:47
Page generated in 0.35382 seconds with 10 queries
