S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
01-01-2005, 20:40 | #1 (permalink) |
Junior Member Join Date: Nov 2003 Location: Seville, Spain
Member: 45214 Status: Offline Thanks Meter: 0 | C65 with bootcore damaged I tell you... I made a full flash read with SST 5.31, without problems. After, with VKlay, I patched this full flash with the patch to enable dev menu in C65. With SST 5.31 again, I uploaded this patched full flash to the phone. Now the phone does not turn on, and can't enter in service mode, so I can't upload the backup flash because is unable to boot. I've tried with SST, x65 flasher, VKlay and Siemens EEPROM tool and always get the same problem, it's unable to boot and I can't do anything I've got backup of fullflash and EEPROM made with SST before uploading the bad pacthed flash, and backup of bootcore extracted with VKlay from the backup fullflash before patching. ¿Can I do something to repair the phone?, I've read this forum a lot but all the solutions are for a phone with a bootcore working, what is not my case... Thank yoy very much guys for your help. |
01-02-2005, 10:34 | #3 (permalink) | |
No Life Poster Join Date: Sep 2003
Member: 38795 Status: Offline Thanks Meter: 106 | Quote:
Did you use a cracked version of SST? | |
01-02-2005, 20:35 | #5 (permalink) | |
No Life Poster Join Date: Oct 2000 Location: Croatia Age: 50
Member: 2254 Status: Offline Thanks Meter: 3 | Quote:
What news you have in v5.36,only dongle protected as I see,but cracked work very well. BTW I m realy sorry because thay "cracked" it(only one working key was needed) ,because 100Euro in realy not much for that kind of SW. br | |
02-12-2005, 15:33 | #6 (permalink) | |
Freak Poster Join Date: Jun 2002 Location: Sanok, Poland Age: 40
Member: 12835 Status: Offline Thanks Meter: 23 | Quote:
1. Flash by WinSWUP (ex. c65_250400_service) but You must SKIP pre-Check and post-Check. 2. after this your phone can goes into testmode :-). Flash it with x65flasher 1054 and FUBU (ex. C65_new_v12_FullFlash.bin) 3. Repair phone with SST-GSM 5.32 For me it works great :-) BR | |
02-12-2005, 16:58 | #7 (permalink) | |
Insane Poster Join Date: Dec 2004 Location: _-°TUNISIA°-_ Age: 42
Member: 98353 Status: Offline Thanks Meter: 1 | Quote:
can i u se for exp c65_250100_service or c65_090100_service by WinSWUP to do that ??? and then update it with c65_410100.exe ??? Plz help.. Thx.. | |
02-12-2005, 19:19 | #9 (permalink) | |
02-13-2005, 15:37 | #10 (permalink) | |
Sorry but i don't know that... but you can make full backup (in SST read flash) and then try if something goes wrong you can write back your fubu Best Regards | |
04-26-2005, 08:37 | #11 (permalink) |
No Life Poster Join Date: Jun 2003 Location: core iXX Age: 48
Member: 32403 Status: Offline Thanks Meter: 139 | i have same problem.i have full backup but phone not enter in test mode .i Flash by WinSWUP c65v25 but update is denied by mobile.why?bad cAble? |
04-27-2005, 06:03 | #12 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
04-27-2005, 06:27 | #13 (permalink) |
Insane Poster Join Date: Feb 2004 Location: Russia Age: 49
Member: 55536 Status: Offline Thanks Meter: 0 | Some info is here: http://forum.gsmhosting.com/vbb/show...0&postcount=17 and here: http://forum.gsmhosting.com/vbb/show...2&postcount=33 All x65 phones can be unlocked now (with testpoint method, if You have testpoint picture for your phone model). P.S. Testpoint picture for S65 needed. |
04-27-2005, 07:40 | #14 (permalink) |
Insane Poster Join Date: Mar 2004 Location: Romania Age: 44
Member: 58646 Status: Offline Thanks Meter: 0 | I have same thing like Birdo, and the batery was low voltage. The phone does not charge with bad soft. Charge the batery with anoher working phone and after that flash with c65 flasher with your backup but make full eeprom access patch, and afther that make map for unlock and the phone is working. salam. |
>>> FG: Siemens C65 Fix BootCore & Unlocked Again <<< | RNC_EBM | FuriousGold | 1 | 08-05-2011 12:32 |
New SST v7.55 with bootcore recovery feature repairs "beeb problem" in S68,E71,C81 | SST-GSM | SST-Dongle | 22 | 07-19-2007 08:06 |
Need fullflash with bootcore for a52 | kamillo | E-Gold Based Phones | 0 | 03-17-2007 15:19 |
Need fullflash with bootcore for a52 | kamillo | x4x, x5x Flashpatching | 0 | 03-17-2007 14:51 |
I need bootcore/EEPROM/Flash backup of C60 WITH bootcore Bug | Chris02 | E-Gold Based Phones | 1 | 04-17-2004 08:30 |
