Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 08-03-2005, 16:59   #1 (permalink)
Member: 165361
C65 dead after bad testpoint help
how can i repair my C65 version 50 ! bad testpoint!
i have cut track now totaly dead help!
Old 08-03-2005, 17:41   #2 (permalink)
Member: 7911
You will have to repair the track - on the C65, you don't cut this track, just short it to ground during boot.
Old 08-04-2005, 16:12   #3 (permalink)
Member: 165361
always totaly dead! please help!
Old 08-04-2005, 16:16   #4 (permalink)
Member: 7911
Have you repaired the track? If so, then you either cut too far into the PCB and damaged one of the internal traces, or you have damaged the CPU.
Get a powerful magnifing glass, and check around where you made the cut.
Old 02-01-2006, 11:57   #5 (permalink)
PARMATMA's Avatar
Member: 201107
Sonork: 100.1576954
I also cuted tracks and try to joint it again but I think some inner track or something else is painful to me. Can anybody give the solution ? A working phone is dead by testpoints and want solution urgent.
Old 02-02-2006, 21:41   #6 (permalink)
sin_daemon's Avatar
Member: 85774
First time i was trying to make test point i solder too big cable (heavy) to the test poing, and when i released it from my hand - it fall down and cut the test point. I repaired it with more tin. And it works. I don't know your situations. I wanna help, if you can send me Pics of your PCB's
Old 09-05-2008, 00:24   #7 (permalink)
VolcoM's Avatar
Member: 36935
hi, i have a problem whith a c65, the tracks are broken and i dont know how are conected, i atach you a microscope screenshoot to you see the problem, please tell me how connect them.
million thanks
Old 09-05-2008, 20:36   #8 (permalink)
Moderator
dagos's Avatar
Member: 416908
Ok,
see in the picture and solder red line.
Testpoints 1 and 2 (blue color) not to be connected!!!
dagos
Old 09-06-2008, 12:01   #9 (permalink)
VolcoM's Avatar
Member: 36935
ok thanks dagos i will try and post results
thanks
AF51 dead after bad testpoint cut ,help ! jawad8305 E-Gold Based Phones 1 09-15-2009 22:27
Nokia 6085, 5200 dead after bad testpoint NokiaESN Nokia Hardware & Hardware-Repair Area 5 07-14-2008 21:24
C65 dead after bad cut classic mobiles Siemens Hardware Repair Area 4 09-11-2005 15:53
bf3 dead after bad unlock,help me !!!! ali25 BF, BG, TH, BHx Series 4 11-22-2004 06:10
MC60 dead after bad testpoint equinoks E-Gold Based Phones 2 06-27-2004 13:36
Page generated in 0.27245 seconds with 11 queries
