S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
07-21-2008, 16:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: ALGERIA
Member: 447187 Status: Offline Thanks Meter: 107 | C65 dead help dagos Transfer boot ... BOOT loaded ... Getting information ... FlashID: 0089,880D (32Mb) BCORE net! OTP ESN: F774F53B OTP IMEI: 354736006628193 Test bus D0 .. D15 ...OK. Test addresses A2 .. A22 ...OK. Search segment EELITE ... Error reception of data buffer A0FE0010,0000FFF0 failed process with the phone! Error reading segment EELITE! Total I/O Error: 1 pieces. Auto ignition ... Transfer boot ... BOOT loaded ... Getting information ... FlashID: 0089,880D (32Mb) BCORE net! OTP ESN: F774F53B OTP IMEI: 354736006628193 Search segment EELITE ... Error reception of data buffer A0FE0010,0000FFF0 failed process with the phone! Error reading segment EELITE! Total I/O Error: 1 pieces. |
07-21-2008, 17:02 | #2 (permalink) |
Junior Member Join Date: Jun 2008 Location: dhaka bangladesh
Member: 789687 Status: Offline Thanks Meter: 0 | any body helpme m55 ****** Joker Siemens EGOLD Phone Version 0.3.0.6 opened. ****** ****** Sunday, July 20, 2008, at 19:37:26 ****** Open file "D:\Siemens\Siemens\M55_v11_lg4_full_repair\M55_v1 1_lg4_full_repair.bin" for write in Flash. FullFlash file used FlashID: 0001/2212 Start... Loading BootsModel(M55)... Sending StartBoot Ok. Sending MainBoot Ok. Com4 921600 BAUD: Ok. ? ? FlashID: 0089/8854 Flash Size: 8Mb Region(1): Blocks 127, Size 64Kb Region(2): Blocks 8, Size 8Kb Window RAM block: 2048Kb Warning: Not valid Flash Size in set phone model! EEPROM segments not found! FSN: DA00ABE5 -> PhoneID: E5AB00DA OTP IMEI: 353184003226185 HASH: 5AD064F4D53E8D758249E7696D23E698 ReadEEP0067 does not answer! ReadEEP0076 does not answer! ReadEEP5005 does not answer! ReadEEP5007 does not answer! Error: EEP5008 not found! Error: Read EEP5009 answer code 0x0! Error: Read EEP5077 answer code 0x0! ReadEEP5121 does not answer! ReadEEP5122 does not answer! |
07-21-2008, 18:25 | #6 (permalink) |
Member: 447187 Status: Offline Thanks Meter: 107 | Autostart... ÜTransfer boot... Gestartet im "Service Mode" Ok Erwarte Start des Telefons... Erhalte Informationen: Model: SIEMENS C65 56 lg6 Telefon ist im "Service Mode" IMEI: 354736006628193 SecurityStatus: CustomerMode HWID: 327 Akkuspannung: 65534 mV. Achtung: Falsches Akku (zu hohe Spannung)! Starte den "Normal Mode"... Press Red key ! Autostart... ÜTransfer boot... Gestartet im "Normal Mode" Ok Erwarte Start des Telefons... Telefon wurde durch Fehler abgestellt: EXIT: 000C:F7FB FILE: ddsphw CPSR: 60000030 CepId: FFFF |
07-21-2008, 19:00 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
Use file from http://rapidshare.com/files/119217775/C65_v12_lg1.rar to unlock easy using SKEY/BKEY calculator from Papuautils. dagos Last edited by dagos; 07-21-2008 at 19:06. | |
The Following User Says Thank You to dagos For This Useful Post: |
06-20-2009, 22:28 | #10 (permalink) | |
Freak Poster Join Date: Dec 2001 Location: Shenzhen, China
Member: 7911 Status: Offline Thanks Meter: 7 | . Quote:
C65 dead after bad testpoint help | cooliogsm | S-Gold Based Phones | 8 | 09-06-2008 12:01 |
c65 dead help pls!!!!!!!!!! | mobilecraker | S-Gold Based Phones | 2 | 03-29-2006 08:48 |
help help help c65 dead test poınt ???? | MaHmUt1982 | Siemens Hardware Repair Area | 7 | 07-30-2005 08:06 |
