Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 07-20-2008, 21:41   #1 (permalink)
globalsystem's Avatar
Member: 521295
Sonork: 100.1607380
c65 flash ok,unlock=problem
hello my friend dagos an all gsmhosting member ...
i have problem with c65 when i try to unlock it i get this error:
Checking value of SKEY from page "Codes"...
Auto Ignition...
Transfer boot...
BOOT is loaded...
Pause 2 sec...
Getting Information...
FlashID: 0089,880D (32Mb)
C65 SIEMENS 353663000574713
HASH: 58000F9208130E3EBF10C3C587EBCCD3
OTP ESN: F8982269
OTP IMEI: 354763004010372
Attention: there is no conformity OTP IMEI and records IMEI in BCORE!
We use OTP IMEI :354763004010372!
Bcore R65 series found
Reading of segment BCORE...
Errror of reception of the buffer of data A0000000,00010000
Failure of process of communication with phone
Error at data reading of segment Bcore!
In total Errors I/O
Old 07-21-2008, 00:14   #2 (permalink)
Member: 163721
reduce Com-Speed
or try Midlet method
Old 07-21-2008, 04:49   #3 (permalink)
Moderator
dagos's Avatar
Member: 416908
Auto Ignition...
Transfer boot...
BOOT is loaded...
Pause 2 sec...
OTP ESN: F8982269
In total Errors I/O
Hello my friend,
in the flashing process, you flashed the bootcore area.
So, to solve this problem, you need to use the "trick" presented on http:///vbb/showthread.php?t=566635
Other option is to transform your phone in SL65, but you need first to repair the bootcore....
Best regards,
dagos
Old 07-21-2008, 10:01   #4 (permalink)
Member: 521295
Sonork: 100.1607380
...not working my friend
i selected many flash files and when i try to put phone in service mode.the phone show service mode but papua 'ont detecte the service mode
i think this phone is dead if you d'ont have other solution MR DAGOS
Old 07-21-2008, 16:17   #5 (permalink)
Moderator
dagos's Avatar
Member: 416908
...not enter in service mode (because your bootcore area is changed). Just go to Flash menu, check only "??????OTP IMEI", "Recalculate Keys" (AUTOMATICALLY IS CHECKED OTHE THREE OPTIONS) and connect tespoint. Click on "Do the Job!" and wait to write bootcore area with the good HASH. After this connect in Service Mode (your phone is unlocked).
dagos
Old 07-21-2008, 17:29   #6 (permalink)
Member: 521295
Sonork: 100.1607380
no not working same problem
am sorry my friend thanx for ur attention
Old 07-21-2008, 17:36   #7 (permalink)
Moderator
dagos's Avatar
Member: 416908
...remain only one solution to fix your problem. Connect using X65flasher and testpoint, read and save flash from your phone, archive using winrar and upload to rapidshare (send me link in PM). I will try to *******te your problem.
Br,
dagos
Old 08-11-2008, 23:57   #8 (permalink)
Member: 123581
Hi All
I Have One Siemens C6v Sfr And I Want To Unlock It
Plz Any Help
I Dont Have Box But I Have Serial Cabel
Thanks
Old 08-12-2008, 04:09   #9 (permalink)
Moderator
dagos's Avatar
Member: 416908
Originally Posted by abdel- View Post
Hi All
Plz Any Help
Thanks
...first you need to have the serial service cable (like C55 datacable) and papuautils software. If your firmware version is lower (<36) you can unlock directly using code calculation. If your firmware is highter (>36) you need to unlock your phone using java midlet (Viper, BsReader). Search on this forum how to unlock S-Gold phones using papuautils.
dagos
Old 08-28-2008, 12:55   #10 (permalink)
Member: 834485
Hi master,
I use papua v1.1.1b to remove "PHONECODE LOCK" error-
it appeared when I enterd 3times a wrong code,
and now,when I use "5008 phonecode" to remove lock it ask to enter SKEY in phone
what's mean that? please help me!!!
Old 08-30-2008, 20:04   #11 (permalink)
Moderator
dagos's Avatar
Member: 416908
Originally Posted by khankhaje View Post
Hi master,
...if your firmware is lower (<36) use SKEY/BKEY calculation (from the CODES menu). If your firmware is higter (>36) use midlat calculation. If you use the midlet calculation, first, you need to activate SIMSIM function (enter in Service Mode -> click on Simulate Sim) and after use midlet calculation (presented in the more posts here)....
dagos
help FLASH oK unlOCK NOT dONE PlzZZZ HELp nejm Z3X-Team Products 4 03-17-2010 07:51
1208 flash ok imei problem challengesenthi Nokia Hardware & Hardware-Repair Area 2 12-31-2008 08:36
x6-2 flashing ok unlock took credit but not unlocked multimedia box SMTi 2 04-24-2008 05:45
Need help on K610i : flash OK, unlock OK but... makroud Sony Ericsson 9 03-22-2008 23:48
hi siroya u600 flashing ok imei problem help cellman899 UST Pro II 3 07-14-2007 15:26
Page generated in 0.43056 seconds with 11 queries
