S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
10-28-2008, 11:19 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Pakistan
Member: 49285 Status: Offline Thanks Meter: 51 | C65 Flashing Problem |
10-28-2008, 17:57 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
I gived response on the other forum: ...in your case, remain only to fullflash using testpoint procedure using x65flasher. If your bootcore not damaged (normarly in the flashing process, bootcore is skiped), just: -open X65Flasher -connect testpoint (not solder, only touch resistor to the testpoint pad). -click on "Connect" button -connect shortly two pins on the keyboard/LED connector to start phone -disconnect testpoint (see message on the flasher window). You have three secconds to disconect it. -click on "Write Flash" and select your fullflash file. -wait to finised... If your bootcore is affected, you need to open X65Flasher with MS-DOS command "x65flasher /b" . Only with this command you flash including the bootcore area. After fullflash, use papuautils to unlock it (with direct calculation or with Java midlet). If you flash included bootcore area, write to me to give information how to unlock your phone and change HASH based on your OTP IMEI. That is... dagos | |
The Following User Says Thank You to dagos For This Useful Post: |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
C65 file system flash problem | spako | S-Gold Based Phones | 2 | 11-28-2007 10:08 |
a problem with c65 flashing | YOUSSI | S-Gold Based Phones | 0 | 07-21-2006 12:46 |
a problem with c65 flashing | YOUSSI | S-Gold Based Phones | 0 | 07-20-2006 12:07 |
C65 flashing problem | Icaros | S-Gold Based Phones | 3 | 10-13-2004 09:43 |
