-   S-Gold Based Phones (http://forum.gsmhosting.com/vbb/f340/)
-   -   C65 new probleme and Big problem (http://forum.gsmhosting.com/vbb/f340/c65-new-probleme-big-problem-232643/)
riadh_tn 09-09-2005 09:23
i have c65 V41. its dead. after just connecte and read and now imei is worrong, now I can't repair imei I can't flash phone I can't do any thing just read phone with
when i flash the handset said flash type not supported.
I rehot the flash IC probleme is always the same.
I use martech Box
plz I need some help
hallo 09-09-2005 09:51
If Martech say..
..that Flash IC is not supported, than take the Flash IC and look good(with microscope) on PCB contacts. If they are OK, than change Flash IC and IMEI U can change with proper free tool, and by way dicrabed on the forum(just use search1)
Cheers
riadh_tn 09-09-2005 10:06
thx m8
but don't forget it's V41 we need test point and I have just test point with martech but can't change imei alwayes not supported ....I trayd with sst craked with the same test point but not work.
riadh_tn 09-09-2005 16:37
ok
what's the solution if test point is domaged for C65
Chris02 09-10-2005 11:36
Originally Posted by riadh_tn
ok
What means damaged??
japunlock 09-10-2005 14:22
it testpoint is damaged you need to remake it (by damaged i understand that cannot see the point)
to repair this phone you have to replace flash ic theres no other wayi had 2 of this and could do nothing else
Page generated in 0.14159 seconds with 5 queries
