Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 09-09-2005, 09:23   #1 (permalink)
riadh_tn's Avatar
Member: 21553
Sonork: 100.114141
Thanks Meter: 220
C65 new probleme and Big problem
i have c65 V41. its dead. after just connecte and read and now imei is worrong, now I can't repair imei I can't flash phone I can't do any thing just read phone with
when i flash the handset said flash type not supported.
I rehot the flash IC probleme is always the same.
I use martech Box
plz I need some help
Old 09-09-2005, 09:51   #2 (permalink)
hallo's Avatar
Member: 21365
Thanks Meter: 86
If Martech say..
..that Flash IC is not supported, than take the Flash IC and look good(with microscope) on PCB contacts. If they are OK, than change Flash IC and IMEI U can change with proper free tool, and by way dicrabed on the forum(just use search1)
Cheers
Old 09-09-2005, 10:06   #3 (permalink)
riadh_tn's Avatar
Member: 21553
Sonork: 100.114141
Thanks Meter: 220
thx m8
but don't forget it's V41 we need test point and I have just test point with martech but can't change imei alwayes not supported ....I trayd with sst craked with the same test point but not work.
Old 09-09-2005, 16:37   #4 (permalink)
riadh_tn's Avatar
Member: 21553
Sonork: 100.114141
Thanks Meter: 220
ok
what's the solution if test point is domaged for C65
Old 09-10-2005, 11:36   #5 (permalink)
Chris02's Avatar
Member: 41076
Thanks Meter: 53
Originally Posted by riadh_tn
ok
What means damaged??
Old 09-10-2005, 14:22   #6 (permalink)
japunlock's Avatar
Member: 87396
Thanks Meter: 63
it testpoint is damaged you need to remake it (by damaged i understand that cannot see the point)
to repair this phone you have to replace flash ic theres no other wayi had 2 of this and could do nothing else
new and big problem N95 8gb the jinnah Nokia Base Band 5 ( BB-5 ) 1 08-09-2009 12:19
W880i-CID53 new unlock java big problem Nurettin Duman SETool2 0 10-14-2008 20:02
New User have big problem!! rabbito Smart-Clip 1 09-27-2006 08:21
C65 new probleme and Big problem riadh_tn SIEM Service Tools 10 07-14-2006 13:32
Page generated in 0.25491 seconds with 8 queries
