S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
03-24-2007, 20:13 | #1 (permalink) |
No Life Poster Join Date: May 2006 Age: 18
Member: 269198 Status: Offline Thanks Meter: 78 | c65 turn off when connect cable i have not been able to unlock any c65 when i insert the cable c55(china) to c65 phone and check (acc) i.e *#06# and more the phone just turn off, what the problem please help me |
03-25-2007, 04:45 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
Your C55 cable it is possible to have wrong (or missing) tension on pin1 (autoignition). Try to unlock C65 phones using DCA500; DCA510 cable, papuautils and the java midlet. For the DAC510 (with autoignition) download driver from: http://rapidshare.com/files/15829026...dapter_848.rar br, dagos Last edited by dagos; 06-15-2008 at 15:40. | |
03-25-2007, 06:13 | #4 (permalink) | |
Member: 269198 Status: Offline Thanks Meter: 78 | Quote:
thanks for your reply, i have followed this solution solder Pin 2,5,6 and 7 together , now i can see acc Plugged in dca-510 but still cannot connect to papuatuils | |
03-25-2007, 15:21 | #6 (permalink) | |
to use the DCA510 (data cable) with service cable, you need to conect pins 5 (CTS) and 7 (DCD) to pin2 (GND) with 10 Kohms resistor. If you conect pin6 (RTS) to GND (with 10 Kohms) and on pin 1 you have +5v automaticaly your phone enter in charging mode. So, conect pins 5 and 7 to pin 2 (with 10Kohms resistors), install DCA510 drivers and set to COM3 the papua software. Br, dagos | |
03-25-2007, 20:04 | #7 (permalink) |
Member: 269198 Status: Offline Thanks Meter: 78 | thnks all for your reply, i.ve been able unlock a c65 v25 i.ve used ufs and directcom with originally shipped ufs cable(not modified) the phone can go into service mode smoothly and unlock ok with papua thnks |
E370 turn on when connect cable | Ciux | UST Pro II | 1 | 08-08-2008 11:15 |
e105 turns off when charger connected | HUM | Samsung Hardware Repair | 0 | 01-07-2007 02:37 |
SDIO WiFi turns off when XDA turns off | bankir | HTC & PDA WM( With Touchscreen) | 0 | 09-06-2006 08:46 |
Sony Z5 turns off when headset/cable plugged in | Gaborrr | Sony Ericsson Hardware Repair | 2 | 02-18-2002 00:03 |
