Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 11-08-2008, 14:57   #1 (permalink)
Member: 69514
c72 can't connect
I used ufs cable & usb to serial converter to connect c72.I can read phone info IMEI etc.means cable is o.k but when I use it with papuautils in fash mode selecting pause & replace options clicking dojobs it says autostart ,boot not loaded,boot unlock & process stops .I have connected t.p to gnd with 33 ohm resistor.attached full charged battery but always says same error .what is wrong please help
Old 11-08-2008, 15:37   #2 (permalink)
Moderator
dagos's Avatar
Member: 416908
..to working in the Flash menu from papuautils, need to your phone to be off (not in service mode). After check options, click on Do the Job and push shortly On/Off red button from your phone (or touch the two pins of the keyboard PCB connector).
Note:
- not in working this this menu only if you know what you want to do...
- testpoint options is used only if your bootcore is damaged or write the new bootcore...
dagos
Old 11-08-2008, 15:53   #3 (permalink)
Member: 69514
To unlock mobile I have to use t.p
Old 11-08-2008, 16:38   #4 (permalink)
Moderator
dagos's Avatar
Member: 416908
...to unlock your mobile not needed TP.
Just check "??????OTP", "Recalculate Keys", "Pause" and click to "Do the Job". See in the "Codes" menu if you have write IMEI and SKEY). If not, write any 8 numbers (for SKEY).
dagos
Old 11-29-2008, 18:39   #5 (permalink)
aao1308's Avatar
Member: 580020
please I don't understand how to unlock network and phone code for c72 with mobilex beta v3.0 beta 1.3b ?
is there any manual for the soft and could you explain step by step for siemens c72 ?
thank very much. Sorry but I'm a new user
can't connect to server, connection refused formative Universalbox 11 12-29-2008 07:33
can't connect to server...connection refused rahulk99k Universalbox 4 12-29-2008 07:30
Can't connect UFS when other FTDI interfaces connected kasner SonyEricsson (USB-Smart) 12 10-26-2005 17:03
I need help , i have COM port connection and i can't connect to the phone starmad Nokia Digital Core Technology 4 ( DCT-4 ) 3 10-01-2004 20:11
Page generated in 0.24097 seconds with 11 queries
