Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 09-19-2008, 10:14   #1 (permalink)
alamgarh's Avatar
Member: 358694
C72 completely dead
I have get one C72 dead but some time just little beep, I try to conect it to X65 FLASHER, But it failed, Please give me a good way to solve it.
Old 09-19-2008, 16:22   #2 (permalink)
Moderator
dagos's Avatar
Member: 416908
...you need to use the testpoint procedure with X65Flasher software and include bootcore in the flashing process (use MS-Dos command: x65flasher /b to start). Connect testpoint, click on "Connect", disconnect testpoint (three secconds) and start flashing.... After flash you need to use papuautils with testpoint. Check only "?????? OTP", "Pause" and from Recalculate Keys keck all options (in the Flash menu). Connect testpoint, click on "Do the Job!", , short two pins from the display/keyboard connector (function power on), disconnect testpoint (you have three secconds for disconnection - see message in the right window - papua) and wait...
That is...
dagos
The Following User Says Thank You to dagos For This Useful Post:
A55! dead, ON for a 1 sec, only vibrate, & completely dead! AE177 E-Gold Based Phones 1 08-14-2003 20:17
a36 completly dead frigor1 x1x to x45/x50 2 12-14-2001 02:14
Completely dead SIEMENS C25 v53. Jurik x1x to x45/x50 18 09-22-2000 18:40
Does anybody know to restore completely dead C 25 v 53? Hardware or software solution Jurik x1x to x45/x50 1 09-11-2000 12:49
C25 complet dead enduro x1x to x45/x50 0 08-31-2000 21:35
Page generated in 0.41324 seconds with 11 queries
