Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 01-30-2009, 00:38   #1 (permalink)
Member: 324705
C75i I-Mode Deads...No Power....
Mr. dagos please help me....
Problem of this phone was auto off...
Ive flashed it with X65 Flasher
and i used SIEMENS_C75_V11lg92_ID_0089_880d_ff.bin flash file
it was pack in a rar file named C75_FF.RAR
now phone is dead...but i can go to SERVICE MODE...
this is the logs of PAPUA
Boot in "Service mode"...
Press RED key (Power ON)!
Auto Ignition...
Transfer boot...
Boot in "Service mode" Ok
Awaiting Power On phone...
Getting Information:
Model: SIEMENS C75 11 lg92
Phone is in "Service Mode"
IMEI: 356270007974206
SecurityStatus: CustomerMode
HWID: 341
Accumulator Voltage: 4392 mV.
Attention: Incorrect adjustments of the accumulator!
X65Flasher...........
whats the next move now???
Old 01-30-2009, 05:18   #2 (permalink)
Moderator
dagos's Avatar
Member: 416908
...after any fullflash, you need to unlock your phone (using papuautils, for example...).
BE carrefully!!! You flash your phone (inside in your phone you have AMD 29LV128MH/L flash chip) with fullflash for Intel flash chip (0089)!!!
I suggesdt to stop any activity and search fullflash file for AMD flash chip. Upload your fullflash file and give to me link to see for which flash chip is...
For unlocking, see bellow:
...open X65papuautils. NOT ENTER IN SERVICE MODE!!! Go to the "Codes" menu and if you have the original SKEY, write in this case. If not, write any 8 numbers in this case. Go to the "Flash" menu and check only "Pause", "??????OTP" and all options in "Recalculate Keys" (if you check this option, automatically is checked the other three options). ONLY THIS PRESENTED OPTIONS NEEDED TO BE CHECKED, NOTHING ELSE!!!!
Click on "Do the Job!" connect testpoint, push shortly phone Power On button, disconnect testpoint (see message -> three seconds to disconnect it), and wait to finalyse ( between reading and writing eeprom segments will have pause somme seconds -> not disconnect). The final message will be : Close all connections...
NOTE: Because you flash your phone with SKEY (i see in your picture) use this key...
dagos
Old 01-30-2009, 05:33   #3 (permalink)
Moderator
dagos's Avatar
Member: 416908
...download C75i fullflash file from: http://rapidshare.com/files/191428116/C75i_v22_lg3.rar
Flash it and post papuautils log.
dagos
The Following User Says Thank You to dagos For This Useful Post:
Old 01-30-2009, 05:36   #4 (permalink)
Member: 324705
Ok sir i'm downloading now.....
hope it works......
can i add you in MSN???
or add me....
dyowei@hotmail.com
thanks...
Old 01-30-2009, 06:10   #5 (permalink)
Member: 324705
dagos
Already flashed....
but can't power on....
do i need to do this????
read codes in papua
Getting Codes from phone...
Model: SIEMENS C75 22 lg3
Phone is in "Format FFS?"
IMEI: 000000000000000
HWID: 341
Accumulator Voltage: 3768 mV.
Error switching to mode BFB!
Old 01-31-2009, 08:41   #6 (permalink)
Moderator
dagos's Avatar
Member: 416908
Already flashed....
read codes in papua
...you need to unlock it with testpoint!
Otherwise not working!
Remember to check "??????OTP" otherwise yout IMEI will be 000000000..
dagos
The Following 2 Users Say Thank You to dagos For This Useful Post:
Old 02-08-2009, 01:56   #7 (permalink)
Member: 324705
@ dagos.....
phone is working now....
i flashed with x65 flasher..
and unlock with Furious Gold...
but..keypad are disabled...
i cant press any key...
and even joystick cant use....
i've got error while unlocking in FG...
it says...
can't calculate skey.....
Old 02-08-2009, 04:25   #8 (permalink)
Moderator
dagos's Avatar
Member: 416908
@ dagos.....
it says...
...again:
enter in Service mode using papuautils, copy from the right window and post here to see what is happened. Because your phone have I mode (C75I) is possible to be branded to the one provider....
I will loocking for solution in your case.
dagos
Old 02-08-2009, 07:29   #9 (permalink)
Member: 324705
Originally Posted by dagos View Post
...again:
dagos
Auto Ignition...
Transfer boot...
HWID: 341
Accumulator Voltage: 3771 mV.
Old 02-08-2009, 17:22   #10 (permalink)
Moderator
dagos's Avatar
Member: 416908
Auto Ignition...
Transfer boot...
HWID: 341
...after fullflash not working simple calculation. Use the testpoint procedure:
dagos
Old 03-20-2009, 07:37   #11 (permalink)
Member: 324705
bumping this thread..................
phone working ok now...
thanks to mr. dagos...
but now i cant change language
does this flash file have Language pack for English???
Old 03-20-2009, 19:05   #12 (permalink)
Moderator
dagos's Avatar
Member: 416908
C75 -> LG03: English, Polish, Russian, Latvian, Lithuanian, Estonia, Ukraine
Verify this fullflash file using Smelter software.
dagos
Genie dead no power on... [ANSWERED] lchico Genie Universal 1 03-29-2010 07:18
6610 can put in local mode but no power on VinhHai Nokia Hardware & Hardware-Repair Area 4 01-11-2010 07:36
Local mode but no power on ??? H@idour Twisterflasher 3 09-15-2005 12:54
Help 2100 dead,no power... topnoyze Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 08-12-2004 10:04
3310 dead no power nokia_pinoy Nokia Hardware & Hardware-Repair Area 3 03-22-2002 10:20
Page generated in 0.61235 seconds with 11 queries
