Cable problem with M65 Dear board members, Last week i buyed original siemens dca-500 cable. i`ll try to use it with,Flasher,V_Klay 3.1,Data Exchange Software,Mobile Phone Manager,seems to be no contact with all of these programs!!! When i put in *#06# the device tells me acc: plugged in: DCA-500 When i make contact with for example vissie,simoco,s25@once, there is no problem! So what the **** is wrong or am i doing wrong! It drives me crazy!!!!! So if somebody would be so kindfull to help me out of this problem! WbR Rossifan |
hrm You sure the correct COM ports are selected for those programs? |
Yep,i`m not a newbee tried everything even on every com speed,but no succes! I also heard that many times it`s a real hard thing to connect your M65 with pc programs! Now i`m giving a list with thing i`ve tried: Change com port speed in programs and computer: NO RESULT Turning on/off the device :NO RESULT Tried Eeprom tools : NO RESULT i don`t know what is wrong,,,,,, maby it`s cable? Like i said before i`m using DCA-500 and that should be original but very slow! Need realy some help to solve this problem! only this problem! |
It is necessary for you DCA510 or no name 3 wires com cable. |
Flasher, v-klay and eeprom tool are not working with DCA500. DCA500 is just data cable. Not service one. For these softs you have to use service cable. If you want to modify DCA500 to work as service one, put 3.5 - 4.5V to pin 1 (+) and pin2 (ground). You can use e.g. charger as power supply. It is tested and it works. But I can not understand, why MPM doesn't recognize M65. Try select "auto connection" in setup. And wait for a while. MPM works too slowly. |
Ok ! So my original cable will be useless ??? **** buyed that m***** for 15 euro ! If i knew this before,i would have buyed a 510 or no-name Thanx anyway! |
Do not save money and buy DCA510!!! You receive original, fast USB cable, with charge from USB, indication Rx, Tx, power + functions with all number line of phones x55-x6x and the software. |
Meh What they all said. I've a DCA 510, it's got the cool little green lights that shows when data's being transferred. Works just fine with V KLay and all the others. |
Ok thanx to all of you for the great help! i`m gonna buy me that DCA-510,after i solved my dust problem! Wbr Rossifan |
Do this cable (DCA 500) has the same problem with CX65 too or only M65? |
