Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 01-07-2005, 11:22   #1 (permalink)
Rossifan's Avatar
Member: 11291
Cable problem with M65
Dear board members,
Last week i buyed original siemens dca-500 cable.
i`ll try to use it with,Flasher,V_Klay 3.1,Data Exchange Software,Mobile
Phone Manager,seems to be no contact with all of these programs!!!
When i put in *#06# the device tells me acc: plugged in: DCA-500
When i make contact with for example vissie,simoco,[email protected], there is no problem!
So what the **** is wrong or am i doing wrong!
It drives me crazy!!!!!
So if somebody would be so kindfull to help me out of this problem!
WbR
Rossifan
Old 01-07-2005, 19:53   #2 (permalink)
Member: 43094
hrm
You sure the correct COM ports are selected for those programs?
Old 01-07-2005, 20:01   #3 (permalink)
Rossifan's Avatar
Member: 11291
Yep,i`m not a newbee
tried everything even on every com speed,but no succes!
I also heard that many times it`s a real hard thing to connect your M65 with pc programs!
Now i`m giving a list with thing i`ve tried:
Change com port speed in programs and computer: NO RESULT
Turning on/off the device :NO RESULT
Tried Eeprom tools : NO RESULT
i don`t know what is wrong,,,,,, maby it`s cable?
Like i said before i`m using DCA-500 and that should be original but very slow!
Need realy some help to solve this problem!
only this problem!
Old 01-07-2005, 20:20   #4 (permalink)
locer's Avatar
Member: 8435
Thanks Meter: 7
It is necessary for you DCA510 or no name 3 wires com cable.
Old 01-07-2005, 20:27   #5 (permalink)
Member: 103416
Flasher, v-klay and eeprom tool are not working with DCA500. DCA500 is just data cable. Not service one. For these softs you have to use service cable. If you want to modify DCA500 to work as service one, put 3.5 - 4.5V to pin 1 (+) and pin2 (ground). You can use e.g. charger as power supply. It is tested and it works.
But I can not understand, why MPM doesn't recognize M65. Try select "auto connection" in setup. And wait for a while. MPM works too slowly.
Old 01-07-2005, 20:28   #6 (permalink)
Rossifan's Avatar
Member: 11291
Ok !
So my original cable will be useless ???
**** buyed that m***** for 15 euro !
If i knew this before,i would have buyed a 510 or no-name
Thanx anyway!
Old 01-07-2005, 21:01   #7 (permalink)
locer's Avatar
Member: 8435
Thanks Meter: 7
Do not save money and buy DCA510!!! You receive original, fast USB cable, with charge from USB, indication Rx, Tx, power + functions with all number line of phones x55-x6x and the software.
Old 01-07-2005, 22:55   #8 (permalink)
Member: 43094
Meh
What they all said.
I've a DCA 510, it's got the cool little green lights that shows when data's being transferred. Works just fine with V KLay and all the others.
Old 01-08-2005, 11:08   #9 (permalink)
Rossifan's Avatar
Member: 11291
Ok thanx to all of you for the great help!
i`m gonna buy me that DCA-510,after i solved my dust problem!
Wbr
Rossifan
Old 01-08-2005, 11:49   #10 (permalink)
anuroj_007's Avatar
Member: 66180
Do this cable (DCA 500) has the same problem with CX65 too or only M65?
Problem With M65! NELU-GSM Siemens Hardware Repair Area 4 09-26-2006 23:19
problems with m65 PIHOC S-Gold Based Phones 1 08-06-2006 15:44
Cables Problem with the new update 5.0 toukour Blazer 16 10-02-2004 22:54
Data Cable problems with 3600 Jobe99 Nokia Multimedia 0 03-27-2004 15:25
Page generated in 0.36382 seconds with 8 queries
