Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2004 Age: 31
Member: 70573 Status: Offline Thanks: 38
| Cleared New Flash? Prob on C75 i have C75 V24 with Phonecode prob i can backup it by x65flasher V2.103 but can't read phone, recalculate with PapuaUtils + TP(Flash phone in phone : Spansion S99-50085) Log with PapuaUtils Ver1.1.1a : Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... FlashID: 0001,227E (32Mb) Cleared New Flash? OTP ESN: AC15008C OTP IMEI: It is not written down or incorrect Boot released. Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... FlashID: 0001,227E (32Mb) Cleared New Flash? OTP ESN: AC15008C OTP IMEI: It is not written down or incorrect Bcore R65 series found Search of a segment EELITE... Search of a segments EEFULL... Find blocks: 52,76,5008,5009,5077,5121,5122,5123 In total EEP blocks: 234 Replacement of blocks EEPROM in the buffer ... EEPROM: Block 76 replaced. EEPROM: Block 5008 replaced. EEPROM: Block 5077 replaced. EEPROM: Block 5009 replaced. Record of the changed blocks in phone... Write down EEPROM segments... Error of a code of acknowledgement of a command of deleting of a segment A0020000! No acknowledgement of a command of write of a segment A0020000! Write: addr:A0020000,size:00020000, buf:45 45 4C 49 54 EEPROM write down error! Repeat operation! i try Repeat with all ver papua 1.0.8, 1.1.1b,079f but have same result Pls help! |
| | #2 (permalink) | |
| Moderator ![]() Join Date: Dec 2006
Member: 416908 Status: Offline Thanks: 3
| Quote:
first give to me more detailes: -which cable you use? -in your phone now have empty flash? -try to connect with papuautils, click on "Information" and post log file. dagos | |
| | #3 (permalink) |
| Thanks Mr Dagos for fast replay! 1. I use direct COM + Universal cable 2. Phone have in Phonedisable!phonecode(i thing it's not empty flash) 3. connect with papuatils : Boot in "Service mode"... Press RED key (Power ON)! Auto Ignition... Transfer boot... Boot in "Service mode" Ok Awaiting Power On phone... No answer on? Ping Boot in "Service mode"... Press RED key (Power ON)! Auto Ignition... Transfer boot... Boot in "Service mode" Ok Awaiting Power On phone... No answer on Ping No answer from the phone Check port number, cable, phone, mode! what is Prob?( i can backup it with X65flasher + TP) |
| | #4 (permalink) | |
| Quote:
Regarding to the phone lock message, you need only to unlock it using papuautils, enter in Service Mode, go to the "Various" menu and click to "5008 Phone Code".... If you want to make backup from your phone, not use the testpoint procedure. Just calculate SKEY and BootKey with papuautils using code calculation methode or Java midlet and export config.ini file to the X65Flasher folder (click on "x65flasher.ini" tab). If you not solve the connection problem, I propouse to use C55 serial data cable or DCA510 USB cable (modifyed). dagos | |
| The Following User Says Thank You to dagos For This Useful Post: |
| | #5 (permalink) |
| Hi, i try test this phone with C55 serial data cable but same result(all my cables work normal with other phone) i thing it's HW prob bcs after service mode on soft, phone go sevice mode but soft can't read anything from phone. with X65flasher i can read eeprom,bootcore,fullflash from phone, can i use this file(eeprom), recalculate with papuaultils without data from page Code then rewrite to the phone to unlock my phone? or any solution for my phone? Thanks Advance! |
| | #6 (permalink) | |
| Quote:
Try to rehot microcontroller (using hot air generator) and after try to unlock using papuautils (or fullash using X65flasher).... dagos Last edited by dagos; 03-27-2010 at 04:12. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need 2610b version 5.65 RH-87 Flashfile (MCU,PPM,CNT) and flash probs on UFS3.... | mic9 | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 03-25-2009 13:51 |
| where can i get new flash file on N70 | bubbles | Nokia Base Band 5 ( BB-5 ) | 0 | 03-20-2006 18:28 |
| New Flash File On Sagmaster Support | mitek | SagMaster Team OLD Products | 5 | 05-20-2005 20:52 |
| new flash id on 2100 | G$M solution | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 06-23-2003 21:15 |
