Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 01-10-2006, 12:40   #1 (permalink)
djirda's Avatar
Member: 95250
Thanks Meter: 2
CX70 CX7i CX7C CX7V what is the diference?
I know they are very similar.I think V is for vodafone but what about CX7c and CX7i?
Old 01-10-2006, 13:02   #2 (permalink)
Bohosh's Avatar
Member: 14741
Thanks Meter: 118
The only difference is in bootcore!!!
Old 01-10-2006, 14:41   #3 (permalink)
dead_dogy's Avatar
Member: 51693
Thanks Meter: 9
I dissagree with you!There is two different PCB for these models,the new one is dark green colour with RF(Infineon) and need different flash(flash IC is same)!
Old 01-15-2006, 18:12   #4 (permalink)
Chris02's Avatar
Member: 41076
Thanks Meter: 53
CX70 is normal retail version
CX7i is the emoty edition (I guess)
CX7C is asia edition
CX7V is Vodafone Edition
Difference is only in Software!
Old 01-15-2006, 18:40   #5 (permalink)
Member: 14468
Thanks Meter: 50
in bootcore you find string model of phone!
if you modify this you can write what swup you want!
best regards
vali
Old 01-15-2006, 19:13   #6 (permalink)
Member: 26577
Thanks Meter: 29
And how can you modify the string model of phone? Whitch software can do it?
I've read it before, but i don't find now. Please help me!
WBR Norberto_
Old 01-15-2006, 19:46   #7 (permalink)
Chris02's Avatar
Member: 41076
Thanks Meter: 53
any flasher to read bootcore (x65 flasher, v_klay...) and hex editor
Old 05-16-2006, 02:40   #8 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
Thanks Meter: 108
fullflash will not do the thing?For example upload full flash to cx7v from cx70 and then use swup to change the language you want. What you think Chris02?
I did that to one c6v,I flashed it wih c65 full and then changed language with swup for c65.
Old 05-16-2006, 02:46   #9 (permalink)
ChIcO*GsM's Avatar
Member: 152205
yes chris
do we have 2 make any bootcore changings on this condition?
Old 05-16-2006, 14:32   #10 (permalink)
BB-gsm's Avatar
Member: 75765
Thanks Meter: 702
@ iki
Yes sure, it is possible as well !
Regards,
B
Old 05-19-2006, 16:42   #11 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,241
if you want, for example,
make M6v (vodafone) to normal M65 :
- read, calc and enter SKEY into phone,
(with java applet or if version lower than 36, then without java, just papuas)
- use x65 flasher, connect phone, change model number (under Advanced)
- use normal M65 flasher to flash non-vodafone software
- power on phone, and use FFS_Init for M65 ...
this procedure makes normal m65 ..
b.r.
Alexandar.
Old 05-23-2006, 14:34   #12 (permalink)
Member: 104088
CX7i Is I-mode version I tried to install Fw to cx70 and nothing happend
Old 05-24-2006, 21:28   #13 (permalink)
Member: 7911
Thanks Meter: 7
No, it won't work - use x65flasher to change the model to "CX70" first, then reflash with the standard firmware.
what is the diference between these updates hasnain FuriousGold 2 08-13-2009 12:05
what is the diference between "SAFE" and "2 SAFE" dazexy CAR Electronics 6 05-09-2009 11:28
What is the diference between Small Vygisbox and Big Vygisbox? rushwhq VygisToolbox 3 10-23-2008 05:57
What is the diference betwenn the BROWN and RED firmware? Wesli TOTAL MultiServer 2 01-30-2005 06:25
UFS-3 or Twister Flasher What is the Diferences afacandenis UFS2 + UFS3-Tornadoflasher 12 05-15-2004 10:05
Page generated in 0.35823 seconds with 8 queries
