S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
10-15-2005, 16:48 | #1 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 190898 Status: Offline Thanks Meter: 47 | Dead M65 Checking values SKey from page "CODES" ... Using Skey: 5752**** AutoIgnition... Transmit Boot... Boot loaded ... Retrieve information... FlashID: 0001,227E SIEMENS M65 3536670058***** Wrong information ! HASH: 733EA4DB10E93DB48A5********* Unregistered version ! Use ESN from page "CODES" ! OTP ESN: F68181F7 OTP IMEI: 3536670058***** All EEP blocks: 233 Block 52,76,5008,5009,5077,5121,5122,5123 found . Error code asknowledge command erase segment A02207A3! No ask. tocommand writting segment A02207A3! Impossible replace block 5008! Replace not good- check phone ! I tried to write to phone rapair flash, but vklay do error in about 21% of flashing. How to repair it? Please help Last edited by MAD_zenek; 10-16-2005 at 10:19. |
10-16-2005, 21:08 | #4 (permalink) |
Member: 190898 Status: Offline Thanks Meter: 47 | I cant write firmware, because there is error in flashing at 21%. I cant unlock phone by papuautils by SKEY too: Enter key.... SKey enter ! Wrong key ! What a ***** phone :/ any solutions to repair it? |
10-16-2005, 21:42 | #6 (permalink) |
Member: 190898 Status: Offline Thanks Meter: 47 | Battery is full, cable is good too (flashing other phones 100% ok) i use SST 5.32 and Vklay. I have entered SKEY now (deleted old eeprom and flashed new backup from other m65) and i have factory mode, but when i try to recalculate keys in flash, i have that: Error code asknowledge command erase segment A0FE0010! No ask. tocommand writting segment A0FE0010! Impossible replace block 52! Replace not good- check phone ! When i want to do "freeze" i have: Checking value entry and needed block ... IMEI: 353667005****** Cod(05): OTP blocked ! Cod(0D): Keys writted in BCORE! In this mode FREEZE impossible ! (mode is set to factory) how to repair it? :/ |
10-19-2005, 22:21 | #12 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
10-20-2005, 18:07 | #13 (permalink) |
Member: 190898 Status: Offline Thanks Meter: 47 | I cant write blocks: 0x006E0000-0x006F0000. Other blocks i can write with no problem. I have rehoted flash with flux and there is that same. I can't reball bcause i dont have sieves for that BGA :/ |
10-23-2005, 23:05 | #14 (permalink) |
Member: 190898 Status: Offline Thanks Meter: 47 | Ok, now i have repaired EEPROM, but there are another problems: 1. Freeze failed? OTP IMEI: 35366700xxxxxxx OTP ESN: F68xxxxx ×ňĺíčĺ áëîęŕ 5122... SKEY: X575xxxxxx ×ňĺíčĺ áëîęŕ 52... "UNDO " will be set to 01 version ×ňĺíčĺ áëîęŕ 76... ×ňĺíčĺ áëîęŕ 5009... ×ňĺíčĺ áëîęŕ 5121... ×ňĺíčĺ áëîęŕ 5123... Freeze(5): Done,but IMEI-freeze skipped ! Warning!: Remember new codes ! At new power on will be writted keys in BCORE and OTP )! IMEI: 353667xxxxxxxxx SKEY: 575xxxxx BOOTKEY: 018FEF2AD96Dxxxxxxxxxxxxxxxxxxxx IMEI-freeze skipped <== is it OK? 2. Phone dead (beep) Model: SIEMENS M65 25 lg3 Telephone in "Format FFS?" IMEI: 000000000000000 SecurityStatus: CustomerMode HWid: 321 Battery voltage 3969 mV. Phone was OFF by error : EXIT: 0003:0F80 FILE: family_amd CPSR: 6000001F CepId: 46FF Whats wrong? and how to repair that problem? |
Dead M65 | bbbbbb | Siemens Hardware Repair Area | 8 | 10-25-2005 08:21 |
dead M65 v43 | gosev | S-Gold Based Phones | 1 | 08-22-2005 22:54 |
Dead M65 after Siemens software update | Freud | S-Gold Based Phones | 7 | 07-26-2005 17:51 |
Dead M65 | FITOS | S-Gold Based Phones | 12 | 06-30-2005 05:55 |
Dead M65 ? | Futuro | S-Gold Based Phones | 4 | 03-21-2005 23:20 |
