S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
01-05-2005, 13:56 | #1 (permalink) |
Junior Member Join Date: Dec 2004 Age: 44
Member: 100364 Status: Offline Thanks Meter: 0 | Dead S65 v25 UK Vodafone My phone died (S65 Vodafone UK) when trying to write a MAP file using EEPROM tool 3.15. It failed on blocks 5008, 5009 and 5077. I thought I'd be able to get around it by loading all from phone, adding the MAP blocks, and writing all back (Save All), however this killed the phone. I did a full backup before this using Eeprom tool 3.0 Now the phone just beeps once when I try to turn on, and nothing happens, just a single horizonal line on the screen that fades away. Following advice in another thread the solution seemed to be to use x65Flasher to flash the phone. However it just won't see the phone, although if I enable logging (/L) I can see a byte being received for pressing the power button, and when it beeps (tries to turn on). The only tools I can get to 'see' the phone for a moment is Eeprom tool 3.0. To do this, I hold down Power, and just as the phone tries to turn on, I press Init. It reads the phone info, although IEMI is 00000000000000000. Any further actions (read/write) crash the program. I have also tried Legija's Easy unlocker, which sometimes connects to the phone, shows IEMI 0000000000000000, takes an hour and looks to have finished but no change. The repair option says "power on phone" but never gets any further. V_Klay isn't able to write a bootcore patch to the phone, it just gives up saying i/o error. SST 5.31 has never worked when I've tried it for unlocking, and it still does the same thing. When I try turning the phone on, it says Starting Service Mode. Never any more, same for all functions. I am mainly trying this with a Siemens DCA500 serial cable. I have also tried a China USB cable, but as the phone is dead at the moment, no COM port exists as the USB isn't there. Is there any hope for this handset?? Thanks! |
01-05-2005, 14:29 | #2 (permalink) |
No Life Poster Join Date: Sep 2004 Location: in AXE control room Age: 54
Member: 84300 Status: Offline Thanks Meter: 74 | Mybe someday when someone discover testpoint,(if exsist). You obiesly failed to patch eeprom ( if u patch bootcore ???) . U MUST patch eeprom to see block 5008,5009 ....IF U NOT SEE at load all eeprom this block, U CANOT vrite map to eeprom,because u dont have patched flash. IF u have patched bootcore ( ? ), u must write full flash ( if u have backup),- skip botcore . AND full flash MUST be patched with AUTOPATCHER. In that case u can write map in eeprom and revive u phone. |
01-05-2005, 16:01 | #3 (permalink) |
Junior Member Join Date: Jan 2005 Location: Slovakia Age: 55
Member: 103416 Status: Offline Thanks Meter: 0 | Crumarix1 is right with eeprom blocks and patch for block "unlocking". Concerning sst and v_klay: those tools will not work with DCA500 cable (if you did not modify it to service cable). You need serial service or usb DCA510 cable. China usb cable is not good one, because when phone is switched to service mode, virtual com port disappear from your system. |
01-05-2005, 16:12 | #4 (permalink) |
Member: 103416 Status: Offline Thanks Meter: 0 | I just read one post in slovak forum, guys who killed CX65 by "Save all" in eeprom tool, repaired it with SST. CX is now alive and working well. So try another cable and SST. |
diferent betwen BB5 vodafne UK and Just UK vodafone | mobile-phone-service | Gsmfather The Wholesale Unlocking Database | 10 | 05-25-2008 14:59 |
**www.UnlockByIMEI.co.uk ® - Vodafone UK In Minutes, Motorola Fast And Much More** | yasin_shafi | Main Sales Section | 0 | 03-25-2008 16:51 |
3G UK , Vodafone UK , T-Mobile Uk , Motorola seimns samsung Via Imei , any Blackberry | ..::Mr999::.. | Main Sales Section | 0 | 07-13-2007 15:05 |
Remote Unlocking: 3 UK, Vodafone UK, Motorola | remoteunlocker. | Main Sales Section | 0 | 01-09-2007 12:00 |
s65 v25 got white screen after unlock with sst | sallu | S-Gold Based Phones | 6 | 06-17-2006 11:32 |
