Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 03-06-2008, 18:18   #1 (permalink)
Member: 31246
E71 unlock problem
i try to unlock 2 phones E71 but no SKey.
I used BSReader and have the hash+esn keys, but papuautils cannot calculate skey, tried with tp but no success. any idea to calculate this skey ?
Old 03-06-2008, 18:33   #2 (permalink)
Moderator
dagos's Avatar
Member: 416908
Hi,
I have somme questions:
-which version of papuautils you used?
-If you used BsReader midlet with papuautils, normarly needed to automatically write ESN and HASH inside (in the papuautils case).
-which firmware you haved inside in the phone?
dagos
Old 03-06-2008, 19:17   #3 (permalink)
Member: 31246
tried with ver.38dEng, 77Eng and 111a197.
can u explain more how to write automatically ESN and HASH inside ?
thx in advance for your help
Originally Posted by dagos View Post
Hi,
dagos
Old 03-06-2008, 19:50   #4 (permalink)
Moderator
dagos's Avatar
Member: 416908
Hi (again),
I you know ESN, (readed directly from the phone), write in the papuautls case in the following order:
-ESN from the phone: A1B2-C3F4
-write in the papuautils: F4C3-B2A1
Instruction for unlocking used PapuaUtils
(Detailes provided by Hacktek)
my 1st ME75:advices and assistance needed
-USE DATA CABLE- with SiMoCo (or the other Phone Manager)
..and never disconect the cable!
- Copy Viper or bsReader(Viper.jar or bsReader.jar to phone in: "Data\Java\jam\Applications"
- start aplication (into phone) -» Data\Applications-»Viper (or bsReader)
- Confirm local conexion 'By Session'.
- Confirm acess aplication java to data cable.
-Wait few seconds (or minutes).
- wait for a 'beep' and the IMEI/ESN/HASH should in phone.
-dont touch nothing and run x65flasher-1072 (or the other X65 flasher version).
-click connect, so the 'keys' calculate starts. wait the calculate.
- start x65PapuaUtils and click button 'PX65V4' - program starts receiving imei/esn/hash from java aplication.
- Click "Calculate Skey and Bkey' and wait skey e a bkey to be calculated
- turn off the phone,
-USE UNLOCK CABLE
- GO 'ServiceMode'.
- click'Enter Skey to phone'.now all keys are saved
- Go'ServiceMode'.
-Enter Skey to phone', should appear 'FactoryMode'.
- Cick'Freia.log'. dont save the log, CANCEL. after that the prog ask if you want write blocks directly to phone. click Yes.
- Program write the blocks.
dagos
Old 03-07-2008, 08:12   #5 (permalink)
Member: 31246
With BSReader i don't see where it asks to confirm local connexion "by session" ans so on, but with viper when press this connexion it gives connection failure.
Hi (again),
dagos
Old 03-07-2008, 09:41   #6 (permalink)
Member: 31246
After asking to "Allow java application to acess accessory?" when press yes i receive this message : Error Java.lang.NoClassDefFoundError:com/siemens/mp/io/File
what to do ?
Old 03-07-2008, 17:26   #7 (permalink)
Moderator
dagos's Avatar
Member: 416908
what to do ?
...in this case write on the paper HASH and ESN, write manually in the phone; for ESN write in the phone D4C3-B2A1 (phone display in the following order ESN: A1B2-C3D4) and click to calculate SKEY.
dagos
Old 03-08-2008, 11:33   #8 (permalink)
Member: 31246
i wrote it like this, but it gives "keys not founds" when i press to calculate SKEY+BOOTKEY.
and the version of this is 37.
dagos
Old 03-08-2008, 12:29   #9 (permalink)
Moderator
dagos's Avatar
Member: 416908
...this is the normal. You used high version....
You need to use testpoint procedure:
-go to the "Flash" tab.
-chose Pause.
-chose 76,5008,5009,5077 in recalculate keys.
-Do the Job!
you must detach tp when ask "pause 2 seconde".
..and after few secconds your phone is unlocked.
Br,
dagos
Old 03-08-2008, 18:27   #10 (permalink)
Member: 31246
thanks, can i give the correct pinout for unlock serial cable please ?
-chose Pause.
-Do the Job!
Br,
dagos
Old 03-09-2008, 06:29   #11 (permalink)
Moderator
dagos's Avatar
Member: 416908
...see bellow:
Pin1: + Power charger or Autoignition
Pin2:GND
Pin3:TX
Pin4:RX
dagos
Old 03-10-2008, 11:48   #12 (permalink)
Member: 31246
this pinout is not correct for unlock serial cable, can u check it, please ,
GND is at pin5.
...see bellow:
Pin2:GND
Pin3:TX
Pin4:RX
dagos
Old 03-12-2008, 18:55   #13 (permalink)
Moderator
dagos's Avatar
Member: 416908
GND is at pin5.
...sorry it is true (E71 use Nano Lumberg connector):
Pin1: RTS (D+ for USB DCA140 cable)
Pin2: CTS (D- for USB DCA140 cable)
Pin3: TX
Pin4: RX
Pin5: GND
Pin6: DCD
Pin7: Ignition (power charger)
Pin8: GND Microphone
Pin9: MICEA
Pin10: Stereo2_Out
Pin11: Phantom_Buff_Out
Pin12: Stereo2_Out
dagos
Old 08-06-2009, 15:14   #14 (permalink)
khunglong0401's Avatar
Member: 412395
E71 RM-346 unlock ok thanks zulea hiiiii
Nokia e71 Unlock Problem curtisbcm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 03-26-2010 22:42
e71 unlock problem phone not entr "local mode" khalid0909 Universalbox 4 01-14-2010 08:39
e71 unlock problem tr3pplea Nokia Base Band 5 ( BB-5 ) 7 10-23-2009 23:37
Unlocking problem with Nokia E71 munir0410 Universalbox 3 11-13-2008 12:33
E71 unlock problem Shahzad. Universalbox 5 11-08-2008 07:28
Page generated in 0.63539 seconds with 11 queries
