S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
05-08-2008, 01:12 | #1 (permalink) |
Junior Member Join Date: May 2008
Member: 767992 Status: Offline Thanks Meter: 0 | Sl75 Escada flash error. Anyone knows what's the problem? My wif has a SL75 as well and I flashed it with no problem. Thank you very much for your help in advance. Mac |
05-08-2008, 18:00 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
dagos | |
05-08-2008, 21:10 | #3 (permalink) | |
Member: 767992 Status: Offline Thanks Meter: 0 | Quote:
I hope you'd bear with me because I am new to this! The phone is connected fine I can communicate with it through Papua! I tried skip pre-check as you said but that did not work either! Maybe there is another way to fix this phone, please let me know if you can. Basically there is a problem with the file system right now, I have 2 sets of everything under "my stuff" 2 sounds entry, 2 pictures entry and so on! That causes issues when I try to transfer stuff from/to the phone, I keep getting error messages that folders don't exist. The other problem is bluetooth, under "visible to others" there is nothing to pick, no settings!! And the final issue with the phone is T9, only English works and nothing else! Please let me know if you can help. I can use papua if you can tell me where to start. Thanks again. | |
05-08-2008, 21:13 | #4 (permalink) | |
Getting Information: Model: SIEMENS SL75 52 lg1 Phone is in "Normal Mode". SecurityStatus: "FactoryMode" IMEI: 35002***45*****9 HWID: 411 Accumulator Voltage: 4118 mV. Code(05): OTP is Closed for write Code(09): BootKEY is stored in EEPROM Code(0D): Keys is stored in BCORE Code(13): Full access to BFC functions Code(15): Full mode (not SC) Code(19): The control is On Code(1D): 512x blocks presents EELITE Info: free buffer 104636 bytes, free at all 105164 bytes, free for deleted 105164 bytes. EEFULL Info: free buffer 43827 bytes, free at all 220993 bytes, free for deleted 89953 bytes. MAP info: Date: 06/11/06, Variant: A 809, Std-Map/SW: 1/44, D-Map/Prov.: 141/45 Factory (OTP) IMEI: 350021384586329 - matches to flash data. ESN: B57E**** HASH: 3964A379013AB19E4A0AB6AE0A584E0A BKEY in block 52 = 7C061A12B42E1A615CBA2CC457C35D1B SKEY in 5122 = "X" 12345678 Minimum number of firmware: 01. Bcore ID: 0202, version: main_1.0_V11 ". Phone operated: 39756 sec.. Total Talk time: 0 sec. FlashID(2) - Manufact. code:0001, type: 227E2223. DisplayID(1,59): Epson L2F50333T. | |
05-09-2008, 05:44 | #5 (permalink) | |
in your log file (readed from papua - info) seems to be everyting OK. For what you need to make downgrade (from your phone FW52 version to the FW47) ??? To make the firmware downgrade you need to have the service cable (serial SIE C55 cable, DCA500 or DCA510) and make it with option Skip Pre-Check.... If you find the other Language Pack for your phone (for the last Firmware 52) doesn't exist other, only LP 01 (the same with in your phone). If you want to have the same startup ring, pictures....you have two options: - use Phone Manager (with your data cable) save in your PC sounds, pictures.... from first phone and upload in the second phone. - make fullflash backup (using service cable) from the your wife phone (with FW 47), fullflash your phone (use X65Flasher) and unlock it with papuautils. To connect in service mode with X65Flasher and Papuautils you have SKEY and BKey calculated (in your log file...). I propouse to use the first option That is. dagos | |
05-09-2008, 21:41 | #6 (permalink) |
Member: 767992 Status: Offline Thanks Meter: 0 | The phone is dead now! I tried to back up the files using the Phone Manager but I kept getting errors so I went with the full flash from the other phone. Now, the phone does not start, when I push the power button I only get a click, that is it. I can still access the phone in papuautils but can't get it in factory mode, I guess the codes changed! I can also get X65Flasher to connect to the phone so I just need the proper way to do this. BTW, I did not back up the Bootcore, do I need to? I don't know what happened, I was very careful! Do I need to back up the bootcore too? How do I get X65Flasher to do it because it won't now, it says something about/B!! Any suggestions will be greatly appreciated and thanks. |
05-09-2008, 22:04 | #7 (permalink) |
05-10-2008, 06:55 | #8 (permalink) | |
Search on this forum, exist more posts HOW TO UNLOCK S-Gold phones using testpoint procedure. dagos | |
05-10-2008, 17:53 | #9 (permalink) |
Member: 767992 Status: Offline Thanks Meter: 0 | dagos, Thank you. I searched around for the tp stuff for the sl75 but could not find any pics or diagram. Do I have to open the phone to do that? Thank you for taking the time to help me out, I am new to this and hopefully one I can return the favor to someone else. |
05-11-2008, 05:24 | #10 (permalink) | |
To use the testpoint, you need to open your phone.... For the testpoint pictures, download from http://papuas.allsiemens.com/TP_SL75.rar This operation is complicated, you need to know how to do it and you need to working only with PC and phone PCB. I suggest to fullflash again your phone using X65Flasher ( I hope you don't modifyed the bootcore area) and lower SL75 firmware version. I will search and give it to you. Normarly, your phone will be connected to X65Flasher. Try this and send me in PM the config.ini file (this file is located in the X65Flasher folder root. dagos | |
05-11-2008, 06:05 | #11 (permalink) |
Member: 416908 Status: Offline Thanks Meter: 398 | ...and download the SL75 lower version from: http://rapidshare.com/files/114054597/SL75_24_FF_.rar dagos |
05-11-2008, 07:47 | #12 (permalink) | |
Member: 767992 Status: Offline Thanks Meter: 0 | Thank you. I just need to figure out the correct way to read the keys via TP. Someone posted this TP at a Russian site, http://img80.imageshack.us/my.php?im...sl75269to3.jpg It is different from what you told me to use? Can I use it, is it safe? Quote:
05-11-2008, 12:09 | #13 (permalink) | |
dagos | |
N96 Weird Flashing error | javakiller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 10-10-2010 11:55 |
1650 flash error | nilesh_patel717 | Nokia Hardware & Hardware Repair | 3 | 03-29-2010 14:03 |
SL75 write flash in SST??? | daroas | SST-Dongle | 0 | 03-03-2008 17:46 |
Flash colour/cid mismatch ,script error : Flash error (10.43.77) | mccm | Cruiser Suite | 18 | 05-22-2007 05:47 |
SL75 full flash | kwitek | S-Gold Based Phones | 26 | 06-27-2006 14:14 |
