Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 05-24-2008, 21:42   #1 (permalink)
Member: 276432
this error with SL75 what is the solution????? please!!
this error with SL75 what is the solution????? please!!TP ON
New sgold detected...
JBOOT: preloader...
20015C1
JBOOT: Failed to execute.
this when i try to full flash
Old 05-25-2008, 04:57   #2 (permalink)
Moderator
dagos's Avatar
Member: 416908
JBOOT: preloader...
20015C1
...hmmm,
seems to the bootcore not runing....
Your phone start normal or not?
Try to connect using serial cable and papuautils software in Service Mode and post log file to see what is wrong.
dagos
Old 05-25-2008, 12:43   #3 (permalink)
Member: 276432
yes my phone is start in normal
Boot in "Service mode"...
Press RED key (Power ON)!
Auto Ignition...
Boot Not loaded!
Phone already in "Service Mode".
Getting Information:
Model: SIEMENS SL75 39 lg6
Phone is in "Service Mode". SecurityStatus: "CustomerMode"
IMEI: 357017001680696
HWID: 411
Attention: Charge Accumulator!
Accumulator Voltage: 3591 mV.
Old 05-25-2008, 12:52   #4 (permalink)
Member: 276432
i have a veru big probem the my pc restart suddenly and now this is the log when i try to boot
Auto Ignition...
Transfer boot...
Boot Not loaded!
Auto Ignition...
Transfer boot...
Boot Not loaded!
No answer from the phone
Check port number, cable, phone, mode!
Save BCORE in a file...
Boot in "BurnIn mode"...
Auto Ignition...
Transfer boot...
Boot Not loaded!
Keys on page Code calculated it is not true!
Updating is stopped!
Input file: E:\John Work\MT-BOX SIEMENS\x65PapuaUtilsV111b\x65PapuaUtilsV111b\BCOR E.bin...
حه âهًيûé ôàéë E:\John Work\MT-BOX SIEMENS\x65PapuaUtilsV111b\x65PapuaUtilsV111b\BCOR E.bin!
زًهلَهٌٍے شَëëشë‎ّ bin ôàéë!
Too small file E:\John Work\MT-BOX SIEMENS\x65PapuaUtilsV111b\x65PapuaUtilsV111b\BCOR E.bin!
Auto Ignition...
Transfer boot...
Boot not loaded!
Invalid BootKEY or not properly joined TP!!
Boot released.
Auto Ignition...
Transfer boot...
Boot not loaded!
Boot released.
Auto Ignition...
Transfer boot...
Boot not loaded!
Boot released.
Attention! With such speed it do not do!
Auto Ignition...
Transfer boot...
Boot not loaded!
Boot released.
Old 05-26-2008, 15:23   #5 (permalink)
Member: 276432
up up up up up up up up up up up up
Old 05-26-2008, 15:51   #6 (permalink)
Moderator
dagos's Avatar
Member: 416908
Auto Ignition...
Transfer boot...
Boot Not loaded!
Auto Ignition...
Transfer boot...
Boot Not loaded!
Auto Ignition...
Transfer boot...
Boot Not loaded!
Auto Ignition...
Transfer boot...
Boot not loaded!
Boot released.
Auto Ignition...
Transfer boot...
Boot not loaded!
Boot released.
Auto Ignition...
Transfer boot...
Boot not loaded!
Boot released.
Auto Ignition...
Transfer boot...
Boot not loaded!
Boot released.
...confused
In your first log, everityng is OK (of course, your phone is locked to the operator). Your PC crashed, restarted and after impossible to connect, right?
Ok, verify com port settings, set com to 115200 bauds, CHARGE battery ( try to if working ). Post your response in the next 30 minutes, because I'm going to the one birthday celebration (my)
dagos
Old 05-26-2008, 20:38   #7 (permalink)
Member: 276432
now my problem it is in my bootcore and i wnat to reflash it how ??????
Old 05-26-2008, 22:17   #8 (permalink)
Moderator
dagos's Avatar
Member: 416908
...you need to make the following steps:
1. Download fullflash file from http://rapidshare.com/files/11784870...400_160208.rar
2. You need to make testpoint. See on attachement ( pictures 1,2,3 and SL75.jpeg).
3. Use x65Flasher for fullflash your phone (included bootcore area). Open MS-DOS window and go to the folder with x65Flasher executable. Run command " x65flasher /b " and the x65flasher window will appair. Connect your phone to X65Flasher using TESTPOINT (you need to make it! Solder only one part of diode and with the seccond part only touch the pad). Click on Connect (testpoint is connected), push Power on (if your phone is opened, you need to short to GND, pin12 from X3801 connector - located up by Joystik) and disconect testpoint (see message in the X65Flasher window). Click on Write flash and select location how is saved fullflash. Wait to finalyse...
4. Open Papuautils, go to the Codes menu and write manually 12345678 (or your old SKEY, if you have it) in skey space. Go to the Flash menu, check ReCalculate Keys (automatically checked the other three) and check Pause.
BE CARREFULLY FOR THIS SETTINGS, NOW YOU WILL WRITE THE BOOTCORE AREA!!!!
Connect testpoint and click on Do the Job!
Disconnect testpoint after mesage appair (Pause 3, 2, 1 - you have 3 only seconds to disconnect testpoint!).
Wait to finish, you will see the message: Boot released. Everything is closed.!
Connect again is Service mode (without testpoint) and see in the log if appair: Phone is in "Service Mode". SecurityStatus: "FactoryMode"
Go to the Normal mode (you need again to push shortly the Power key and see if your phone is started.
If your phone is started, that is...
dagos
Old 05-27-2008, 02:22   #9 (permalink)
Member: 276432
the test oint does not appear and i couldn't see it i connect the scond point but the first is not appear in the attachment
Old 05-27-2008, 04:23   #10 (permalink)
Moderator
dagos's Avatar
Member: 416908
...loocking to the "TP_SL75-2.jpg" (the seccond picture). Testpoint1 is located near by the SIM connector.
dagos
Old 05-27-2008, 14:35   #11 (permalink)
Member: 276432
no i mean the first picture but the second is appear the first picture in your attachment
Old 05-27-2008, 16:16   #12 (permalink)
Moderator
dagos's Avatar
Member: 416908
...OK,
because you don't know how to use this testpoint, use the testpoint by BouRRi_GSM and connect to GND with the 10-50 ohm resistor.
dagos
Old 05-28-2008, 16:51   #14 (permalink)
Moderator
dagos's Avatar
Member: 416908
...I see this error. Not answer from loader -> Not maked testpoint or bootcore damaged (using new bootcore procedure). My oppinion; you need to erase bootcore and flash it again, but you need again to make testpoint....
dagos
Old 05-28-2008, 18:03   #15 (permalink)
Member: 276432
How To Erase Bootcore And What Is The Test Point To Use
what is the solution of damage Potato BOX ???? ..::MOBILES::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 17:03
What is the solution to this letter ehab2500 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 01-25-2010 15:06
What are the problems in the pinfinder and what is the solution tornado2008 SpiderMan 0 06-08-2009 15:19
What is the solution thomas server error 33872 J.A.F. By Jafsupport.com 3 02-19-2009 06:52
look at this log adn tell me what is the problem please stranger55 MT-BOX 2 05-05-2007 19:37
Page generated in 0.58466 seconds with 11 queries
