Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
| | #1 (permalink) |
| Junior Member Join Date: Feb 2005 Age: 43
Member: 114868 Status: Offline Thanks: 0
| Help! C72 cable connexion I have a simple cable for a c55 (writed in it) and rs232 (com1) to 12 pins connector for the phone ; doesn't work for me when i plug-in the benq-siemens c72, i mean dosn't recognized in the pc to use with mpm or simoco ; do i have to modify it?? Please, help me. |
| | #2 (permalink) | |
| Moderator ![]() Join Date: Dec 2006
Member: 416908 Status: Offline Thanks: 3
| Quote:
To use with Phone Manager (SiMoCo, MPM...software - for data transfer) you need to have serial cable (write RS-232 in the serial female connector)or USB to serial cable DCA510. You not have possibility to modify this cable for using to data transfer (is too complicated). dagos | |
| | #3 (permalink) | |
| Quote:
PC USB Pin SIEMENS Pin Description 1 1 USB Vbus 2 4 USB D- 3 3 USB D+ 4 2,5,6,7 GND Pins 2,5,6,7 of Siemens connector are wired together. USB VBus may be not connected - should work without this connection. Is it right?? Do i need a simple usb type "a" for my pc, or a "virtual" usb to serial like prolific 203?? PLEASE help me, i can soldier wires. | |
| | #4 (permalink) | |
| Quote:
-connect pin 5 to pin 2 (in the Lumberg connector) with 10Kohms resistor. -connect pin 7 to pin 2 (in the Lumberg connector) with 10Kohms resistor. -if you want ro realyse charging functions, connect pin 7 to pin 2 (in the Lumberg connector) with 10Kohms resistor and connect Vbus (+5Volts) to the pin 1 in the Lumberg connector. Lumberg connector is connector who is pluged in Siemens phone... See on attachemment, for edification. Cable with the Prolific chip have name DCA510... dagos Last edited by dagos; 03-27-2010 at 04:10. | |
| | #5 (permalink) |
| thank you very much Dagos for these explanation, so i do this cable with a virtual usb to serial chip? Please confirm? it is not a pure usb connector? If so, it's not necessary to have the prolific virtual com chip, i mean the other side of connector of the virtual com, to lumberg, with the 4 wires (i cut an old virtual com cable and i identify the connections)? And please can you explain the connection : -connect pin 5 to pin 2 (in the Lumberg connector) with 10Kohms resistor. -connect pin 7 to pin 2 (in the Lumberg connector) with 10Kohms resistor. Is it a simple connection with a resistor, without connection to the usb? Thank you in advance. |
| | #6 (permalink) |
| ok, i see the schematic, and i diduct that the charging function is optional, and we can read data/flash with this cable without it, isn't it? Last edited by hanon; 01-13-2009 at 09:34. |
| | #8 (permalink) |
| okay! I made 2 type of cable ; one (dca-540 and with charging function with the switcher 550) and the other is the dca 510 i think with the virtual com port OTI 6858 dual TX comm )) i built a USB female on it to be a cable for flashing ) and if i want only data, i let it a dca540!!! waw! fantastic! two type of cable!!! thanks Dagos again. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| HELP!! HELP!! C72 dead!! | hanon | S-Gold Based Phones | 2 | 01-28-2009 11:35 |
| Please Help C72 | MR_DMC | SST-Dongle | 0 | 07-24-2006 08:37 |
| cable problem , help please , cable from telyway | celcom | Cruiser Suite | 6 | 06-24-2005 13:50 |
| Plz HeLp A2618-cables-COM coonection problems | laouily | Old Ericsson Phones & Sony Phones | 0 | 05-28-2001 08:49 |
| He helps with cables A1018,T10 URGENT | cIVIc | Wanted Products | 0 | 10-24-1999 03:36 |
