Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 03-03-2005, 03:22   #1 (permalink)
Member: 41106
help, error with siemens eeprom tool by skylord
Hello all.
when I run the siemens eeprom tool 3.15 by skylord, press "init", it scanning, then I press the red key, it shows me ''run-time error 9""subscript out of range'', what's wrong? my computer is with windows 2000
thanks
Best Regards,
Ben
Old 03-03-2005, 04:00   #2 (permalink)
Member: 49922
What phone model do you have?
Old 03-03-2005, 04:02   #3 (permalink)
Member: 41106
s65 & cx65, the results is same
Old 03-03-2005, 04:03   #4 (permalink)
Member: 41106
s65 & cx65, lang 8, chinese version
Old 03-03-2005, 04:16   #5 (permalink)
Member: 49922
I tried to use the soft in my M65 v43 lg1 using DCA-510 (windows 2000 SP4 + full windows patched) with this setting:
Mobile inisialization
Phone: =x65
Port: COM3
press "init", it scanning, then I press the red key. in phone shows "Service mode ON"
and it recognized the phone information.
or u can try to check the PreCheck box, do it again and see what happen.
Old 03-03-2005, 04:59   #6 (permalink)
Member: 41106
the results is same,
I also use USB DCA-510, com1, then what windows full patched?
ben
Old 03-03-2005, 05:27   #7 (permalink)
Member: 49922
Strange... for DCA-510, I think could not use COM1 or COM2, coz it is basic onboard COM port.
After I install the cable driver, My DCA-510 automatically recognized at COM3 (I have a friend with the same cable, he got COM4).
So, make sure u have the COM port setting, in right position.
* Windows full patch means, I have all windows patch that microsoft launch in their website to make my PC system up to date.
Old 03-03-2005, 06:37   #8 (permalink)
Member: 41106
I have checked with our IT department, our system also is windows 2000 SP4, as my com3 is set as modom, com4 is set as virtual IR port, so I set it as com1 or com2 only.
BR//Ben
Old 03-03-2005, 07:24   #9 (permalink)
Member: 49922
BR//Ben
Ok, you can try to set it as COM5 or above, through System properties -> Device Manager. (Don't use COM1 or COM2)
If problem still exist...uhmm I don't know what to say.
Siemens Eeprom tool 3.15 by Skylord unexpected error vlezlee Siemens-Benq RingTones and WallPapers 3 08-21-2005 22:39
Siemens EEPROM tool by skylord v3.15 - problem with LOAD ALL option PSG Siemens-Benq RingTones and WallPapers 5 07-22-2005 10:21
Can not connect C65 with Siemens Eeprom Tool Anno S-Gold Based Phones 3 12-19-2004 20:38
disable aero check & siemens eeprom tool by skylord doesn't work... eio x1x to x45/x50 1 05-05-2003 13:57
does siemens eeprom tools by skylord work under win2k? eio Siemens-Benq RingTones and WallPapers 0 05-02-2003 08:24
Page generated in 0.28195 seconds with 11 queries
