S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
09-18-2005, 15:06 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: France
Member: 103520 Status: Offline Thanks Meter: 17 | HELP SL65 dead I have a problem with SL65 I make the unlock process with papua - mapper - EEprom tool but when I have connected the phone with eeprom tool phone always turned off himself in few time. So i try and try and always the same thing. Finaly I decide to do it in testmode (phone stay on in testmode) BAD idea just one block writed to the phone and error, so the phone just beep now. I don't know what to do now : complet flash with Veklay (saved password boot for Vklay work fine) or other please need Help ! here is the detail when I try again the complet process: AutoIgnition... Transmit Boot... Boot loaded ... Pause 2 sec... Retrieve information... FlashID: 0089,880D SIEMENS SL65 354220008150787 HASH: 6C65446B64CC1818683F1096FE9DC819 OTP ESN: DCCF316C OTP IMEI: 354220008150787 Boot unlock . #Then go to code# Calculate SKEY an BKEY Keys calculated good : BOOTKEY: 48C4E7B291FAFF80E34F6CD05F022EBC SKEY: 90357328 Recalculate HASH&BKey from ESN & SKey New HASH: 6C65446B64CC1818683F1096FE9DC819 New BOOTKEY: 48C4E7B291FAFF80E34F6CD05F022EBC #Then go to settings# Booting in "Service mode"... Press P.ON ! AutoIgnition... Transm. Boot... Booting in Service Mode Ok Wait to power on phone ... Получение информации: Model: SIEMENS SL65 50 lg1 Telephone in "Service Mode" IMEI: 354220008150787 SecurityStatus: CustomerMode HWid: 324 Battery voltage 65534 mV. Внимание: Failure battery settings ! #Then go to codes# ENTER SKEY IN PHONE Checking entry values..... Test ServiceKey... Enter ServiceKey in phone... SKey enter ! Wrong KEY ! #Then oppen the mapper and make map then oppen the tool EEprom# INIT OK Load map OK SAVE SELECTED 5008 : Error ?15 (WBlockInfoQuery) while writing block ? 5008... You can retry writing skip this block or abort whole writing process. Same thing for 5009 and 5077 Problem is Block 0076 was writed and now the phone don't turn on and beep |
09-18-2005, 17:40 | #2 (permalink) |
Member: 103520 Status: Offline Thanks Meter: 17 | Finaly repared the phone I post the method here maybe can help many peoples: In my mind the problem of this phone wase: Battery voltage 65534 mV. Внимание: Failure battery settings ! this explain maybe why the phone turn off on EEprom tools So I make a full flash with Vklay and after: Battery voltage 3858 mV. That's right ! Then with papua flash tool: Recalculate Keys in Flash and DO JOB : Boot unlock . Checking values SKey from page "CODES" ... Using Skey: 90357328 AutoIgnition... Transmit Boot... Boot loaded ... Pause 2 sec... Retrieve information... FlashID: 0089,880D SIEMENS SL65 354220008150787 HASH: 6C65446B64CC1818683F1096FE9DC819 OTP ESN: DCCF316C OTP IMEI: 354220008150787 All EEP blocks: 230 Block 52,76,5008,5009,5077,5121,5122,5123 found . Old block 5009 saved into 354220008150787_EEP_050918181821_5009 Block5009 replaced. Old block 5122 saved into 354220008150787_EEP_050918181821_5122 Block5122 replaced. Old block 5121 saved into 354220008150787_EEP_050918181821_5121 Block5121 replaced. New Master codesы: *#0000*12345678# *#0001*12345678# *#0002*12345678# *#0003*12345678# *#0004*12345678# *#0005*12345678# Old block 5008 saved into 354220008150787_EEP_050918181821_5008 Block5008 replaced. Old block 5077 saved into 354220008150787_EEP_050918181821_5077 Block5077 replaced. Old block 5123 saved into 354220008150787_EEP_050918181821_5123 Block5123 replaced. Old block 52 saved into 354220008150787_EEP_050918181821_52 Block52 replaced. Old block 76 saved into 354220008150787_EEP_050918181821_76 Block76 not need replace ! Working...BCORE... BCORE HASH not need change ! BCORE IMEI not need change ! Booy unlock . All glued . AT THE END of THAT PHONE TURN ON AUTOMATIC waoooouuuuuuuuu !! Then continue the unlock process successfull without any problems Just it's again an other Flash without French !! but phone work ! |
09-19-2005, 00:16 | #4 (permalink) |
Member: 103520 Status: Offline Thanks Meter: 17 | WAOUU just repaired 2 other C65 from my old stock off dead phone by the same way. Remember mate the Recalculate Keys in Flash fonction from Papuas soft is MAGIC ! Thanks Chris but no way to enter the T9 with Siemens software not working for me Just if somebody have full fubu flash for SL65 and C65 with French please Share |
09-19-2005, 15:27 | #5 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | Quote:
You problem is your cable. I wrote you via mail how to modify it. You can use the T9 file I gave to you for all x65 phone (except A65) | |
10-20-2005, 09:20 | #6 (permalink) | |
Freak Poster Join Date: Feb 2001 Location: Netherlands Age: 40
Member: 3212 Status: Offline Thanks Meter: 10 | Quote:
You can fix it faster.... 1. Connect phone with papua in service mode (custommer)...(you already have SKEY) 2. Open EEPROM tools and write eeprom backup (that youve made before unlocking) 3. You get some errors that it can't write certain eeprom blocks....just ignore it and resume eeprom writing. 4. After that phone is still dead, but battery settings are repaired then.... 5. So in papua tools you can connect again and use the Recalculate Keys in Flash.... 6. Phone is alive again Its almost the same as posted above...but it's much faster | |
11-12-2005, 16:14 | #7 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: ISLAND Age: 54
Member: 80036 Status: Offline Thanks Meter: 25 | Quote:
U are my SUNSHINE | |
sl65 dead,help please | James-R | S-Gold Based Phones | 4 | 05-11-2007 20:07 |
Siemens SL65 dead after write full flash with V10.6 | jean' | SIEM Service Tools | 0 | 01-04-2006 20:59 |
help me on sl65 dead!! | senkron24 | SIEM Service Tools | 4 | 09-06-2005 08:16 |
sl65 dead | James-R | SST-Dongle | 2 | 07-18-2005 15:02 |
SL65 dead after bad unlock... :( | et.com | S-Gold Based Phones | 6 | 06-14-2005 18:09 |
