S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
11-29-2005, 06:03 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | Help sl65 v43 with Papua v038_Eng May someone help am stack and can't go on ,check where am stack with papua v038 _Eng,it stops at factory mode. AutoIgnition... Transmit Boot... Boot loaded ... Pause 2 sec... Retrieve information... FlashID: 0089,880D SIEMENS SL65 354220007401991 HASH: 59D2B594752A8E02C1995821139E1679 OTP ESN: 62E9E418 OTP IMEI: 354220007401991 Boot unlock . Calculate KEYS.. Keys calculated good : BOOTKEY: 63A656A809B7B67BD6ED57882A51EBE4 SKEY: 91097900 Checking entry values..... Recalculate HASH&BKey from ESN & SKey New HASH: 59D2B594752A8E02C1995821139E1679 New BOOTKEY: 63A656A809B7B67BD6ED57882A51EBE4 Checking entry values..... Test ServiceKey... Enter ServiceKey in phone... SKey enter ! Pause 1 second(s)... SecurityStatus: FactoryMode |
11-29-2005, 06:19 | #2 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Harare, Zimbabwe/ South Africa Age: 44
Member: 46546 Status: Offline Sonork: 100.1577435 Thanks Meter: 85 | yes you are on the right track, after factory mode click freia log and shut down 4ne, create map , upload and viola |
12-01-2005, 23:00 | #5 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 42
Member: 104924 Status: Offline Thanks Meter: 8 | if u've the SKey connect ur phone without test point and in the flash tab tick Recalculate master new master codes are put in ur phone it should be like *#0000*12345678# type the new masters made by PaupaUtils and ur phone should be unlocked no need to creat MAP and upload it with EEprom tool but if u want to use the unlockin' by MAP becareful and don't hit Save all in eeprom tool just click on save selected or ur phone will be dead good luck m8 |
Help c72v version 22 problem with papua | chitawira | S-Gold Based Phones | 6 | 04-07-2010 09:27 |
c75 dead unable to connet with papua but can update with winswup | gsnbhagawan | S-Gold Based Phones | 1 | 05-16-2007 13:08 |
Problem reading IMEI & ESN from CF76 with papuas... help! | DJiCE | S-Gold Based Phones | 0 | 12-13-2006 00:52 |
cx70 v 43 unlock with papuas but need help | Amir-SkillZ | S-Gold Based Phones | 3 | 11-10-2005 16:37 |
SL65 v43 lg4 - unlock HELP !!! | Jackill | S-Gold Based Phones | 1 | 09-07-2005 12:46 |
