S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
01-30-2009, 01:38 | #1 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 324705 Status: Offline Thanks Meter: 192 | C75i I-Mode Deads...No Power.... Problem of this phone was auto off... Ive flashed it with X65 Flasher and i used SIEMENS_C75_V11lg92_ID_0089_880d_ff.bin flash file it was pack in a rar file named C75_FF.RAR now phone is dead...but i can go to SERVICE MODE... this is the logs of PAPUA Quote:
X65Flasher........... whats the next move now??? | |
01-30-2009, 06:18 | #2 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote: BE carrefully!!! You flash your phone (inside in your phone you have AMD 29LV128MH/L flash chip) with fullflash for Intel flash chip (0089)!!! I suggesdt to stop any activity and search fullflash file for AMD flash chip. Upload your fullflash file and give to me link to see for which flash chip is... For unlocking, see bellow: ...open X65papuautils. NOT ENTER IN SERVICE MODE!!! Go to the "Codes" menu and if you have the original SKEY, write in this case. If not, write any 8 numbers in this case. Go to the "Flash" menu and check only "Pause", "??????OTP" and all options in "Recalculate Keys" (if you check this option, automatically is checked the other three options). ONLY THIS PRESENTED OPTIONS NEEDED TO BE CHECKED, NOTHING ELSE!!!! Click on "Do the Job!" connect testpoint, push shortly phone Power On button, disconnect testpoint (see message -> three seconds to disconnect it), and wait to finalyse ( between reading and writing eeprom segments will have pause somme seconds -> not disconnect). The final message will be : Close all connections... NOTE: Because you flash your phone with SKEY (i see in your picture) use this key... dagos |
01-30-2009, 06:33 | #3 (permalink) |
Member: 416908 Status: Offline Thanks Meter: 398 | ...download C75i fullflash file from: http://rapidshare.com/files/191428116/C75i_v22_lg3.rar Flash it and post papuautils log. dagos |
The Following User Says Thank You to dagos For This Useful Post: |
01-30-2009, 06:36 | #4 (permalink) |
Member: 324705 Status: Offline Thanks Meter: 192 | Ok sir i'm downloading now..... hope it works...... can i add you in MSN??? or add me.... [email protected] thanks... |
01-30-2009, 07:10 | #5 (permalink) | |||
Member: 324705 Status: Offline Thanks Meter: 192 | Quote:
Already flashed.... but can't power on.... do i need to do this???? Quote:
read codes in papua Quote:
01-31-2009, 09:41 | #6 (permalink) | |
Otherwise not working! Remember to check "??????OTP" otherwise yout IMEI will be 000000000.. ...open X65papuautils. NOT ENTER IN SERVICE MODE!!! Go to the "Codes" menu and if you have the original SKEY, write in this case. If not, write any 8 numbers in this case. Go to the "Flash" menu and check only "Pause", "??????OTP" and all options in "Recalculate Keys" (if you check this option, automatically is checked the other three options). ONLY THIS PRESENTED OPTIONS NEEDED TO BE CHECKED, NOTHING ELSE!!!! Click on "Do the Job!" connect testpoint, push shortly phone Power On button, disconnect testpoint (see message -> three seconds to disconnect it), and wait to finalyse ( between reading and writing eeprom segments will have pause somme seconds -> not disconnect). The final message will be : Close all connections... dagos | |
02-08-2009, 02:56 | #7 (permalink) |
Member: 324705 Status: Offline Thanks Meter: 192 | @ dagos..... phone is working now.... i flashed with x65 flasher.. and unlock with Furious Gold... but..keypad are disabled... i cant press any key... and even joystick cant use.... i've got error while unlocking in FG... it says... can't calculate skey..... |
02-08-2009, 05:25 | #8 (permalink) | |
enter in Service mode using papuautils, copy from the right window and post here to see what is happened. Because your phone have I mode (C75I) is possible to be branded to the one provider.... I will loocking for solution in your case. dagos | |
02-08-2009, 08:29 | #9 (permalink) | |
Press RED key (Power ON)! Auto Ignition... Transfer boot... Boot in "Service mode" Ok Awaiting Power On phone... Getting Information: Model: SIEMENS C75 22 lg3 Phone is in "Service Mode" IMEI: 356270007974206 SecurityStatus: CustomerMode HWID: 341 Accumulator Voltage: 3771 mV. | |
02-08-2009, 18:22 | #10 (permalink) | |
03-20-2009, 07:37 | #11 (permalink) | |
Member: 324705 Status: Offline Thanks Meter: 192 | bumping this thread.................. phone working ok now... thanks to mr. dagos... but now i cant change language does this flash file have Language pack for English??? Quote:
03-20-2009, 19:05 | #12 (permalink) | |
Verify this fullflash file using Smelter software. dagos | |
Genie dead no power on... [ANSWERED] | lchico | Genie Universal | 1 | 03-29-2010 07:18 |
6610 can put in local mode but no power on | VinhHai | Nokia Hardware & Hardware Repair | 4 | 01-11-2010 08:36 |
Local mode but no power on ??? | H@idour | Twisterflasher | 3 | 09-15-2005 12:54 |
Help 2100 dead,no power... | topnoyze | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-12-2004 10:04 |
3310 dead no power | nokia_pinoy | Nokia Hardware & Hardware Repair | 3 | 03-22-2002 11:20 |
