S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
10-27-2005, 12:43 | #1 (permalink) |
Insane Poster Join Date: Feb 2002 Age: 45
Member: 9806 Status: Offline Thanks Meter: 2 | cxt70 v.50 dead after unlock I try to unlock this phone with papua and after I write map I press write all in eeprom tool and now phone only beep.I try to flash with x65 flasher 1072 but soft can not find boot code write The program failed to read boot password. The procedure exited with error message: Key was not found. Possibly some new algoriithm is used. :'( can anybody help me please ? Thanks very much |
10-27-2005, 15:34 | #2 (permalink) |
Member: 9806 Status: Offline Thanks Meter: 2 | Hi I solve this problem I write bad ESN but when I try to write map to phone with eeprom tool 3.15 I get error 15 while writing block 5008, 5009,5077 - this same error which I get when I try to unlock at first time can anybody help pls? |
10-27-2005, 15:56 | #3 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Algeria
Member: 56090 Status: Offline Thanks Meter: 162 | If your phone want power on sure "field 52 is corrupt" ... your problem is only in the eeprom part why you try to flash the phone ? if you have make backup of the eeprom then return it back or try to find eeprom same version and write it to your phone Salam |
10-28-2005, 07:50 | #4 (permalink) |
Member: 9806 Status: Offline Thanks Meter: 2 | Yes friend but I donīt have backup eeprom can anynbody sent me it on [email protected] ? |
help urgently G1157 dead after unlock.. | razisamb | FuriousGold | 4 | 03-29-2010 15:38 |
k510i cid 50 dead after unlock | bacau | SETool2 | 0 | 12-18-2007 12:25 |
e 50 dead after flashing with universal box | totalmanish | Universalbox | 2 | 04-27-2007 12:30 |
Mt 50 Dead after flashing | Lukas123 | x1x to x45/x50 | 3 | 07-28-2002 01:49 |
GD93 Dead, after unlock ON but after some time again Dead... | DrMobile | Panasonic | 1 | 02-14-2002 10:16 |
