S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
12-16-2004, 22:50 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Italy
Member: 26267 Status: Offline Thanks Meter: 1 | MAD USB Cable DCA-540 + CX65 : everything is impossible... 1) often when I plug the cable into the phone and I type *#06# I can see at the end of second page "plugged in DCA-540". Other tymes instead, when I plug the cable, on the top of display the cell shows "TTY" and in *#06# it only show "plugged in". The first case, I've on my Windows ME 2 devices, one USB device and a Siemens Usb Modem ( virtual COM4 ). In the second case, I've only a USB device but I cannot find a correct driver fot this... When the cell shows TTY, there isn't a virtual COM, so no program can work... 2) I downloaded CX65_250100_xbz_tool.exe from my-siemens.com, when my phone says "plugged in DCA-540" the exe give me an error of "type 505". When phone says only "plugged in", the tool says "no COM4". 3) Fortunately I've been able to patch the bootcore with the Chaos midlet... ok. But now, when I try to use V_Klay or X65Flasher and I try to clock on "connect" of the program... my computer freezeeeeee!!! if the phone says "plugged in DCA-540" and it's on. When the phone is off or it says only "plugged in" with TTY, the programs cannot find the virtual COM... |
12-18-2004, 02:55 | #3 (permalink) |
Freak Poster Join Date: May 2004 Age: 61
Member: 66180 Status: Offline Thanks Meter: 0 | @ PYCON Change cable to DCA-510,it works fine Edit and you may find this comment from Siemens official http://www.siemens-mobile.com/com.ap...65_update.html Last edited by anuroj_007; 12-18-2004 at 03:10. |
04-11-2007, 19:47 | #6 (permalink) |
No Life Poster Join Date: Jun 2001 Location: www.microera.si
Member: 4923 Status: Offline Thanks Meter: 74 | Hi! I need ORIGINAL USB CABLE DRIVER for Siemens phone! is this OK: http://drivers.softpedia.com/progDow...oad-16761.html my cable (like this): http://3gnewsroom.mobiles.co.uk/accessory-DCA510.html Please for 100% good cable driver!! p.s. Original Siemens sites are dead! |
04-12-2007, 16:29 | #8 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
it is possible to have Prolific chipset PL-2303 inside. Try with the Prolific drivers: http://www.prolific.com.tw/eng/downloads.asp?ID=31 or download from: http://www.munich-handy.de/usb-kabel_treiber.zip Br, dagos | |
04-12-2007, 16:32 | #9 (permalink) | |
to identify your chipset adapter, go to http://www.handy-faq.de/forum/showthread.php?t=10 and read instruction (in the german language). Br, dagos | |
04-12-2007, 19:59 | #10 (permalink) |
Member: 4923 Status: Offline Thanks Meter: 74 | Hi @dagos THANKS for usefull info! But I install today at morning (before reading your poste): Prolific chipset PL-2303 inside and M65 is recognized .... and after starting SWUP updating ... M65 is switched offf but flashing with SWUP don't start!! similar message " ... ? not received from phone...." occure! ? I will test tommorow again on another computer if I have time .... propably at night! I will poste results here!! |
siemens cf110 and usb data cable dca-510 | 1data2 | E-Gold Based Phones | 5 | 04-11-2009 05:04 |
A65 and DCA-540 | alfa62 | E-Gold Based Phones | 3 | 11-19-2005 17:37 |
Need DCA-540 USB cable schematic diagram | beemer | S-Gold Based Phones | 6 | 05-31-2005 22:22 |
Can patch CX65 by DCA-540 usb cable ? | ^NaT^ | x6x and x7x Flashpatching | 5 | 03-20-2005 11:56 |
DCA-540 : still useful o not? | PYCON | S-Gold Based Phones | 0 | 12-21-2004 18:45 |
