S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
01-31-2008, 23:57 | #1 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 682988 Status: Offline Thanks Meter: 45 | DEAD SL75 help help help help... Phone full flashed, I have to repair its Imei using papua v111, but I get error. Look log: ////////////////////// Checking value of SKEY from page "Codes"... Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... FlashID: 0001,227E (64Mb) BCORE Cleared! OTP ESN: DDB3C25B OTP IMEI: 3570170---------- Bcore S/SL75 found Reading of segment BCORE... Search of a segment EELITE... Search of a segments EEFULL... Find blocks: 52,76,5008,5009,5077,5121,5122,5123 In total EEP blocks: 144 SKEY in block 5122 = "X" 16662060 Replacement of blocks EEPROM in the buffer ... EEPROM: Block 76 replaced. EEPROM: Block 52 replaced. EEPROM: Block 5123 replaced. EEPROM: Block 5122 replaced. EEPROM: Block 5009 replaced. EEPROM: Block 5008 replaced. EEPROM: Block 5077 replaced. EEPROM: Block 5121 replaced. New Master codes: *#0000*12345678# *#0001*12345678# *#0002*12345678# *#0003*12345678# *#0004*12345678# *#0005*12345678# BCORE "Cleared", recalculation impossible Record of the changed blocks in phone... Write down EEPROM segments... Error of a code of acknowledgement of a command of deleting of a segment A0040000! No acknowledgement of a command of write of a segment A0040000! Write: addr:A0040000,size:00020000, buf:45 45 4C 49 54 EEPROM write down error! Repeat operation! ////////////////////// Phone state now: enter in service mode, but only beep when I power on. What's problem? Need your help*help*help thanks. |
02-02-2008, 00:58 | #3 (permalink) |
Member: 682988 Status: Offline Thanks Meter: 45 | Problem is in bootcore!!! All keys recalculated in eeprom, but still ca't do on bootcore, 'cause bootcore is cleared! How to write bootcore? then to recalculate it's key? //////////////////// FlashID: 0001,227E (128Mb) CFI: 4 : 4*32768, 254*131072, 4*32768, 512*131072, BCORE Cleared! OTP ESN: DDB3C25B OTP IMEI: 35701700--------- Bcore S/SL75 found Reading of segment BCORE... BCORE "Cleared", recalculation impossible Boot released. Everything is closed.! ////////////////////// Why I can't write bootcore area using X65flasher? always it skip this step. Please I need your help, thanks. |
02-02-2008, 10:15 | #4 (permalink) |
No Life Poster Join Date: Nov 2001 Location: türkiye Age: 59
Member: 7114 Status: Offline Thanks Meter: 51 | select new bootcore boot type s/sl75 tick,all calculated area is in codes section, but I think your problem is in eeprom write 98 mb full flash and than recalculate keys good luck. regards |
02-02-2008, 13:15 | #7 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Algeria
Member: 56090 Status: Offline Thanks Meter: 162 | I'm waiting your answer .... Second: search in backup folder file with name DDB3C25B*********x.nnn (nnn=BIN or EEP) these files are the backup of your phone ( if the phones come to for unlock we can revive it with these backup files) else do as Ardagul have writed above Third: preferably use x65papuautilsv111b_190 Salam |
02-02-2008, 13:32 | #10 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | post log from papua v111 when u doing TP now (including IMEI) real full flash size for SL75 is 96MB not 98MB including FFS br Last edited by BouRRi_GSM; 02-02-2008 at 13:40. |
02-02-2008, 13:39 | #11 (permalink) |
Member: 56090 Status: Offline Thanks Meter: 162 | ok return to papua (in IMEI case you must see the IMEI of the phone) (in phone you must see SL75) (in HWD you must see 411) (in bcore type you must see s/SL75) (in codes tab you must see ESN, HASH , SKEY and BKEY values not empty values) GO to convert TAB and tick recalc FUllflash and select the file with 98 mb next save it to another name Launch xflasher with bootenabled by typing x65flasher.exe /b select COM and Baud and choose tespoint, do testpoint press connect and flash the phone by ticking on restore all For the moment i'm here but i must go after minutes and i will come back this night if your phone is ok then congratulation for you else we will continue the game héhéhé Salam |
02-08-2008, 14:32 | #13 (permalink) |
Member: 682988 Status: Offline Thanks Meter: 45 | After many retries phone still beep... Then I said phone is dead forever... But phone now alive! Guess what was the solution? I just FORMAT Files system 0! Now phone poser on normaly, no hanging at start up; but doesn't countain photos and ringtones. I will update it to version 37 o 39 then I will write an xfs file, to have a complete clean working phone with files in gallery (I hope that it will not hang again). Thanks you for all. AND DON'T FRGET ABOUT FORMATING YOUR SL75, E71 AND OTHERS WHEN IT BEEPS! IT CAN BE THE SOLUTION. |
05-31-2008, 12:52 | #14 (permalink) |
Junior Member Join Date: May 2008
Member: 783750 Status: Offline Thanks Meter: 0 | SL75 Phone disabled PHONECODE?? I have an SL75 and somebody tempered around with it until it displayed the above message and I can't do anything. I got all my contacts and other audio files of significance on it. Can someone please help me as to how to I can get over this problem. I have no software or cables, so please help!! |
07-26-2008, 11:44 | #15 (permalink) | ||
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
hi.. can u add sl75 full flash..i have full flash but it is 64 mb.. but u r talking about 96-98 mb full flash..can u share it..? thanx... | ||
Dead SL75 AMD by Dreambox | dogeatdog | DreamBox | 9 | 04-22-2008 10:55 |
Dead SL75, how to revive? | mourad_t | S-Gold Based Phones | 0 | 01-06-2008 00:35 |
Reviving 1 dead SL75, now 2 | warmsteel | S-Gold Based Phones | 6 | 11-30-2007 21:06 |
Reviving 1 dead SL75, now 2 UPDATE | warmsteel | S-Gold Based Phones | 1 | 10-23-2007 23:51 |
Dead SL75 an just clic Information!!!!! | arans | S-Gold Based Phones | 5 | 02-11-2007 08:06 |
