Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 12-05-2008, 22:56   #1 (permalink)
Member: 782173
Sonork: Bekky
Pls, Help needed for S65
Pls, I need help for my S65 fw43, please read carefully. I got my phone from my Uncle who live in U.k, he bought the phone as refurbished and send it to me in Nigeria, when I got d phone I found getcodes in my application folder and I deleted it bcos I don't know it Use. Now I want to Update the phone but I failed, I downloaded winswup 50 and 58 and official update 53 from allsiemens.com. Whenever I click on any winswup they give me "xbi header error" I cancel d error but won't let me click on Start and it detects my Com port( I use dca 510 ) even when d S65 is switched off and when I click on official update it gives error of "low memory can't read phone software and when I click on Continue it closes itself. Then one day I mistakely hold down a key and I enter assign hotkey, I saw Developer Menu already activated, I click on it then (S) Exit here are some info that I got:
CPSR: 0x00000000
CepID: 0x0000
Adr: 0x0000000
Project info of Exit:
DB-Name:
klf_ulreneo
SW-Ver:
43
M_c65plat_MP-main_1.0kzdb5#main_1.0_V135.17
Project-Name:
M_pene_int_TH
Developer:
OFFICIAL
BuildTime:
20050128T163528
and here is d info from *#06#
IMEI:
35-7489-00-220755-7
Product:
S65
P.-Date:
2004-08-26
SW-Version:
43
Baseline:
FFS-Version:
S65_2_uk-
UKStandard_12_0239
Fri Aug 20 09:36:10
CEST 2004
- 8535531547
Variant:
A 203
Std-Wap/SW:
1/12
D-Map/Prov:
239/139
Lang./T9:
lg1/0
Codecs:
FR/EFR/HR
Audio-Par:
NfV45
Acc:
None
RegDSP1:
EELITE
RegDSP2:
Patch:29/Audio 7
RegDSP3:
ROM
And later I downloaded x65flasher 2103
Old 12-06-2008, 06:02   #2 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 397
Ok,
first you need to modify your DCA510 cable. Insert two 10Kohms resistor between:
pin 2 -> pin 5
pin 2 -> pin 7
Download from http://rapidshare.com/files/44149250/Service_cable.rar. You have inside the modification cable pictures and X65papuautils software. Use this software for unlock your phone (if is locked) and generate "x65flasher.ini" file (for flashing your phone using X65flasher software). Save this file in the X65flasher root folder.
Download from http://rapidshare.com/files/141368814/S65.rar fullflash file and flash your phone using this file .
To know how to use papuautils and x65flasher software, search on this forum...
After flash, make the firmware update (using your country Language pack SWUP file).
dagos
Old 12-06-2008, 19:22   #3 (permalink)
Member: 782173
Sonork: Bekky
Thanks for Replying me but I can't do that inserting 10kohms resistor to my dca 510 cable am new in Phone stuff but my phone connect to x65flasher2103(hope I can use it and have ones read fullflash and restore that same fullflash to d phone ) ( Can I still proceed without 10kohms~) Am I going to restore my phone with the fullflash downloaded through x65flasher ?
Thanx in Advance
Old 12-08-2008, 04:40   #4 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 397
Thanx in Advance
...if your phone connected to x65flasher with DCA510 cable you not need to instert 10 Kohms resistors (have it inside). Regarding to the fullflash, if you backup your phone and restore backup after, your phone will be in the same status. To understand, your phone working or not? If you have problems with firmware upgrade, format your phone and run after FFSInit and Map files to restore original data in your phone. Fullflashing phone is the last solution (because you need to unlock your phone after).
dagos
Old 12-09-2008, 10:56   #5 (permalink)
Member: 782173
Sonork: Bekky
Sorry for asking too much question but I don't understand this in your last post (Fullflashing phone is the last solution "(because you need to unlock your phone after)" After I restore with the downloaded rapidshare S65 fullflash, won't I be able to switch on the phone ?, play games ?, make calls ?, browse on pc with the phone ? , pls answer all these questions or explain to me better the state of the phone after fullflashing and how will I unlock the phone after restoring or flashing ?
Old 12-13-2008, 13:56   #6 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 397
...after each fullflash you need to unlock your phone (except if you used fullflash backup from your phone). After fullflashing, phone doesn't enter in Normal mode (startup normarly) because manny blocks from fullflash have value (IMEI, SKEY, HASH...) from the backuped phone...
That is.
dagos
Old 02-12-2009, 17:20   #7 (permalink)
Member: 782173
Sonork: Bekky
How do I unlock the phone after flashing ?
Old 02-12-2009, 18:22   #8 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 397
...just search on my post, bro...
Because you have SKEY and BootKey from your old flash, try first to unlock without testpoint:
Open X65papuautils. NOT ENTER IN SERVICE MODE!!! Go to the "Codes" menu and write SKEY (normarly if you unlocked before your phone, need to appeair). Go to the "Flash" menu and check only "Pause", "??????OTP" and all options in "Recalculate Keys" (if you check this option, automatically is checked the other three options). ONLY THIS PRESENTED OPTIONS NEEDED TO BE CHECKED, NOTHING ELSE!!!!
Click on "Do the Job!", push shortly phone Power On button and wait to finalyse ( between reading and writing eeprom segments will have pause somme seconds -> not disconnect). The final message will be : Close all connections...
If give to you error, use the testpoint procedure
...open X65papuautils. NOT ENTER IN SERVICE MODE!!! Go to the "Codes" menu and if you have the original SKEY, write in this case. If not, write any 8 numbers in this case. Go to the "Flash" menu and check only "Pause", "??????OTP" and all options in "Recalculate Keys" (if you check this option, automatically is checked the other three options). ONLY THIS PRESENTED OPTIONS NEEDED TO BE CHECKED, NOTHING ELSE!!!!
Click on "Do the Job!" connect testpoint, push shortly phone Power On button, disconnect testpoint (see message -> three seconds to disconnect it), and wait to finalyse ( between reading and writing eeprom segments will have pause somme seconds -> not disconnect). The final message will be : Close all connections...
dagos
Old 02-19-2009, 22:43   #9 (permalink)
Member: 782173
Sonork: Bekky
I dont think I can do any of above process, pls send me the direct link where I can download good ffsinit, mapfiles or langpack or swfiles for S65 fw43 english (files to restore my phone) as main langugage and send me best or good performance firmware update or software update English ver direct link with its ffsinit and other useful files. Or do U know anybody in Nigeria that can help me with the above process and I'm want to buy another phone, Pls recommend a cheap phone with great features or performance
Old 02-20-2009, 03:36   #10 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 397
Hi,
the all requested filed, you find on the Landy site: http://eh.student.utwente.nl/~landy/index.php?dir=
user: mobile
pasword: elibom
The last firmware for this phones is FW58. The all versions have english language inside....
Regarding to the other phones, is your choise to analyse between price and quality which phone you want to buy...
dagos
Old 02-20-2009, 11:14   #11 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,721
USE MARTECH TO UNLOCK UR PHONE WITHOUT PROBLEM IN 1 MIN
Old 05-25-2009, 12:38   #12 (permalink)
Member: 782173
Sonork: Bekky
FFsinit russian version 12 work with my phone but camera stop working what should I do
Old 05-25-2009, 12:42   #13 (permalink)
Member: 782173
Sonork: Bekky
When U open any firmware update or winswup what is the message will be displayed ?
Pls post me answer, I want to use this to compare the updates that I downloaded maybe they are corrupt
Old 05-25-2009, 12:44   #14 (permalink)
Member: 782173
Sonork: Bekky
Old 05-26-2009, 06:11   #15 (permalink)
Member: 1037943
hello,
I have a Siemens SX1 ,this is My IMEI 352079004106918 and I would appreciate you sending me the phone code.
Thanks in advance
Pls help, Need particular V3x flash for RSD Lite wolf_19 Motorola P2k 0 05-28-2007 08:53
Pls Help!need Gdfs.bin For Z600~ WY.Z600 Sony Ericsson 0 08-25-2004 13:22
pls help need eeprom and full flash for gd68 louay16 Panasonic 0 05-30-2004 04:13
PLS Help, need solution for RC815 Sagem ! ptkrf Infineon C16X M51 & ARM7 M52 BASED 2 04-19-2000 09:55
Page generated in 0.43409 seconds with 8 queries
