S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
05-15-2006, 16:08 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Brazil Age: 44
Member: 77651 Status: Offline Thanks Meter: 21 | is possible FullFlashing sl75 by V-klay??? kadES |
05-15-2006, 20:18 | #3 (permalink) |
Member: 77651 Status: Offline Thanks Meter: 21 | I'm not so sure about that... S75 and SL75 are New S-gold (64mb). I can read the fullflash using V-klay+Papuas loader, but I can't write another FF on it... On V-klay the phone is always showed like: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ; Flash: ID1: 0x0089, Type1: 0x880D; IMEI: 000000000000000; FlashBaseAddr: 0xA0000000; FlashSize: 0x04000000; FlashRegionsNum: 4; Region 1: blocks count=255, size of each=0x00020000; Region 2: blocks count=4, size of each=0x00008000; Region 3: blocks count=255, size of each=0x00020000; Region 4: blocks count=4, size of each=0x00008000; dbg: cache param: No=4,0xA0000000: 0x00020000, 0xA1FE0000: 0x00008000, 0xA2000000: 0x00020000, 0xA3FE0000: 0x00008000, kadES |
05-16-2006, 11:03 | #4 (permalink) |
Freak Poster Join Date: May 2003 Location: Athens, Greece
Member: 29130 Status: Offline Thanks Meter: 5 | But with IMEI all 0's and nothing readable in BCore Model name , it appears that you must have something like a 'clean BCore' ... Does the phone start ? (it should work with a Clean Bcore..., but not accepting updates...) |
05-17-2006, 15:33 | #5 (permalink) | |
Member: 77651 Status: Offline Thanks Meter: 21 | Quote:
Yes. It is working OK, but when I put a simcard it freezes on main screen... How that 'Clean Bcore' option works??? kadES | |
05-18-2006, 16:48 | #6 (permalink) |
Member: 29130 Status: Offline Thanks Meter: 5 | One thing is that its Bcore appear clean and can't accept fw updates either service (winswup) or user updates from Siemens site, and another the ability to write with V_Klay. (if BootKey in V-Klay loader is correct and connects, it can write...) But usually with option "Clean Bcore" in x65PapuaUtils one can get that result. Actually Model Name, Hash, IMEI are cleared from Bcore... Some operation has done on the phone... Maybe function "Freeze" (using OTP IMEI in filed IMEI) could put missing things in Bcore (x65PapuaUtils). But to do this need have correct keys from before, especially Skey to get phone in 'FactoryMode'... Maybe the suggested procedure to 'Recalc keys in flash' could work... Also there is another procedure for difficult cases as described in AllBugSGold.rar although you are NOT in such bad position.... |
is possible write pm by pheonix, how | dexter_mn | Nokia Base Band 5 ( BB-5 ) | 0 | 03-14-2008 16:18 |
i just finish my 250 logs i ask if is possible to buy by 50 logs | mbourtelephone | MT-BOX | 6 | 06-22-2007 09:08 |
Unlock M/MT50 by Maxim - is possible! | Tygiel | x1x to x45/x50 | 0 | 12-02-2002 16:12 |
Is possible repair GD92 destroy by Wolfgang? | Pandemonio100 | Panasonic | 10 | 07-04-2001 17:48 |
