Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 07-04-2005, 09:11   #1 (permalink)
Member: 93094
Unhappy C65 boot, blue screen and other Please help
Hello
First I write that I used search function a lot and I haven't found solution so far.
I've got a problem with c65. It was switching on and worked with blue screen, all functions was ok. Then he powered on from time to time and now phone don't power on.
I can't boot it using papua (aby version). I've made everyting as here: http://babelfish.altavista.com/babel...26highlight%3d It worked for the first time, read esn and hash, but no imei and wrote that "imei is bad in bcore". Then I left it and searched for solution. Next time when I was trying to connect I got message:
AutoIgnition...
Transmit Boot...
Boot loaded ...
Pause 2 sec...
Retrieve information...
Unknown Flash type(ID:0081) čč:
1) Not propper work with TP .
2) No all contacts in PMB & Flash.
3) Corrupted Flash.
4) Corrupted another hardware in phone .
5) Corrupted cable (adapter). Boot unlock .
Then I tried vklay and x65flasher and again with papua and it worked. It looks like if it worked once then it will work again after some time?! Now I can't boot it anymore. I changed coms many times, reboot system and put off battery. I've made testpoint as described using resistor and needle (is this possible if I scratched testpoint?). Any help will be appreciated.
Old 07-04-2005, 12:31   #2 (permalink)
hallo's Avatar
Member: 21365
Thanks Meter: 85
For problems with X65/X70 serie...
.....solution is here http://forum.gsmhosting.com/vbb/show...10#post1229310
So, no more dead siemens phones thank's to men called Papua!!!!
Chers
M55 Blue screen and Buzz ; earlier unlocked with Java patch silhouette E-Gold Based Phones 14 11-22-2012 00:10
A65:when I try to turn it on it shows blue screen and bip and then it turns off by it beneto DreamBox 3 03-04-2010 12:38
j300 with blue screen and phone hangs after89 SonyEricsson (USB-Smart) 2 09-04-2005 12:27
V525 blue screen and turns off. flashed but still same crossings Motorola P2k 4 09-02-2004 09:36
M55 blue screen and Bzzzzzzzzzzzz tgsm E-Gold Based Phones 9 05-10-2004 11:34
Page generated in 0.24078 seconds with 8 queries
