S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
03-23-2006, 23:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Bamako Mali Age: 50
Member: 36261 Status: Offline Thanks Meter: 13 | Problem to unlock C75 by papuas want must do HELP i use Send Boot... BOOT loaded... Pause 2 Seconds... Receive Informationen... FlashID: 0089,880D Error in Data! C75 SIEMENS P Wrong Data! HASH: 0000000075FF19FF1128977D26993213 OTP ESN: CC062737 OTP IMEI: 356272009697256 Attention! OTP IMEI and BCORE IMEI not the same! Using OTP IMEI:356272009697256! Boot is open. Calculate the Key´s... Key´s not found! Calculate the Key´s... Key´s not found! Calculate the Key´s... Key´s not found! |
03-24-2006, 11:27 | #2 (permalink) |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | Hi mates, The readed data are wrong. 1 Try to use Px75v1 midlet to get Hash and ESN 2 use papuaUtils078, It work fine, fill imei,esn (papua), and hash boxes. 3 Calculate skey and note the HWID must be 341 instead of 555 4 Use regular method to unlock it Enjoy Best regards, Aishur |
03-24-2006, 12:55 | #3 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Tunisia Age: 43
Member: 40632 Status: Offline Sonork: 98231 Thanks Meter: 1,658 | use latest version of papua V075e, and tick pause and replace master and you unlock your phone in few seconds no need to calculate Bootkey. |
03-24-2006, 22:17 | #4 (permalink) |
Member: 36261 Status: Offline Thanks Meter: 13 | very happy very thanks to you AiSHUR and YAWACOM i use your advice and now phone works perfect. i make tp master replace then replace block 78. 5008 etc |
04-01-2006, 17:36 | #5 (permalink) |
Junior Member Join Date: Aug 2004 Age: 66
Member: 77717 Status: Offline Thanks Meter: 0 | Hi all I have the same problem with papua when calculate SKEY: Key not found. I tried with many versions of papua and the same result. Reading this thread i read: "use latest version of papua V075e, and tick pause and replace master and you unlock your phone in few seconds no need to calculate Bootkey." I don't understand what Yawacom says. Can anybody explain me this? Sorry for my bad english. |
04-02-2006, 21:43 | #6 (permalink) | |
Freak Poster Join Date: Jun 2002 Location: Spain Age: 52
Member: 13239 Status: Offline Thanks Meter: 3 | Quote:
Regards | |
04-03-2006, 12:35 | #7 (permalink) |
Freak Poster Join Date: May 2003 Location: Athens, Greece
Member: 29130 Status: Offline Thanks Meter: 5 | There might be some problems either with AMD flash types or new BootCore type when using an older PapuaUtils, especially using the "Flash" page or Testpoint method. Better use English 075e, and classic method. Find HASH & ESN with Java ( or maybe recorded in a previous usage of tool) Calculate BootKEY and SKEY. Send SKEY to Phone. Use "Freia.log" and then 'Cancel' in Save dialog to unlock... (in order to offer writing EEPROM blocks) May release SKEY from phone. |
04-03-2006, 12:47 | #8 (permalink) |
Member: 28188 Status: Offline Thanks Meter: 579 | Hi mates, Many users of java midlet mix between Phone Id and esn. you need to try the given esn as follows. Example esn =12 34 56 78 you have to try 78 56 34 12. Papuas is a brute force verification and it should find Skey. However it is fixed with Px71V5, You have esn for Chaos and esn for Papuas. lol... Best regards, Aishur |
04-03-2006, 16:14 | #9 (permalink) |
Member: 77717 Status: Offline Thanks Meter: 0 | I have used this versions of Papua: 0.33 0.38 0.51 0.64 0.69 0.75 and 0.78. I don't find the version 0.75 in english; i paste a image of version 0.38e: Ïîëó÷åíèå èíôîðìàöèè: Model: SIEMENS C65 56 lg1 Telephone in "Normal Mode" IMEI: 3x476x003x17x88 (x=character hidden) SecurityStatus: CustomerMode HWid: 327 Battery voltage 3820 mV. Additional information : Cod(05): OTP blocked Cod(0A): Record Bootkey missing in EEPROM Cod(0D): Keys recorded in BCORE Cod(10): BFC function unaccess Cod(15): Full mode (not SC ) Cod(19): Control ON í Cod(1D): Blocks 512x exists ò Phone worked ë 9754192 sec. Full call time 30836 sec. Flash memory ¹1 - Code fact.: 0089, type 880D Calculate KEYS.. Key not found ! If i use a version in rusian, the two last lines are in all the versions i tested: Ðàñ÷åò êëþ÷åé... Êëþ÷ íå íàéäåí! |
04-03-2006, 18:54 | #10 (permalink) |
Member: 28188 Status: Offline Thanks Meter: 579 | Hi mates, @jr400000 here the version is 56, I guess you didn't used test point or java midlet. To get Hash and esn. you must use java midlet or test point. Maybe you have just cliked information button. Try to upload Px65v5 in your phone and follow usual method to unlock it. Best regards, Aishur |
04-03-2006, 19:18 | #11 (permalink) |
Member: 77717 Status: Offline Thanks Meter: 0 | Hi all. Jesusangel aid me and he has troubled my problem: i put the HASH code on the wrong way, with px75v1 the HASH and the ESN codes it is necessary to put them in papuas as the sample the telephone shown. Thanks to Jesusangel |
i need one guide me to unlock c75 | MTi-GsM | S-Gold Based Phones | 2 | 02-09-2006 12:50 |
help to unlock c75 | ARAB GSM | S-Gold Based Phones | 3 | 01-12-2006 22:15 |
how to unlock c75 and cx75 with sst? | mmanduri | SST-Dongle | 6 | 12-20-2005 00:18 |
help to unlock c75 | ARAB GSM | S-Gold Based Phones | 4 | 11-28-2005 23:01 |
