S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
12-09-2005, 16:14 | #20 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Tunisia Age: 43
Member: 127608 Status: Offline Thanks Meter: 46 | sorry but i have a small ploblem with M65 : in menu screensaver code protection is on, i can't change it off and when phone enter in screen saver mode i have this message : Phone locked please turn off ! |
12-10-2005, 03:10 | #21 (permalink) | |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | Quote:
I your phone have version <= 25 you can Read block 00-02 from your phone and save it in a directory with SST cracked 5.32 or 5.31 then open readed files with X65_fixbootcore and put original imei, then write it again with SST then do repair. I don't test this, but it can help you. Good luck | |
The Following User Says Thank You to BouRRi_GSM For This Useful Post: |
12-10-2005, 07:29 | #22 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 782 | @bourri if i try to flash with sst... it stops only till reading data.. it cant read the imei of the phone anymore... what steps must i do?? if i try to use papuas.. it doesnt boot anymore even with TP.... pls help me.. tnx! |
12-10-2005, 14:54 | #24 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Dubai
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | @BouRRi_GSM i already solved my problem through x65papua and than i flashed it with ver15 and flashed sucessfully but set can't be on and set can't go in service mode through x65papua |
12-11-2005, 14:24 | #25 (permalink) |
Member: 4021 Status: Offline Thanks Meter: 782 | [Bootkeys] 353667004687025=B7355B4835B28171082E2D72F977E13E @bourri can u pls calculate boot code for my m65??? i cant do it really... i rreally need your help!!! |
12-12-2005, 01:11 | #26 (permalink) | |
No Life Poster Join Date: Dec 2003
Member: 47384 Status: Offline Thanks Meter: 8 | Quote:
Do you have fix bootcore for s66? i really need it,please thanks | |
12-12-2005, 15:55 | #27 (permalink) |
No Life Poster Join Date: Jul 2004 Location: GEORGIA,Tbilisi
Member: 75765 Status: Offline Thanks Meter: 722 | @ pali & Rise Flash it with higher versions like 41, recalc keys in flash, (This may be enough or else: ) write eeprom, recalc keys ! Regards, B |
12-20-2005, 22:22 | #29 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: Skopje , Macedonia Age: 40
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | Quote:
best regards | |
can i repair dead siemens m65 with furious?? | hamada33r | FuriousGold | 6 | 04-30-2008 21:17 |
Repair Dead BE4 BE5 WITH DEAD TEH | chip_2000 | Alcatel & TCL Old Models | 25 | 10-23-2005 09:18 |
K750 dead.... can anyone explain more detail?? | PhoneDeal | SonyEricsson (USB-Smart) | 7 | 08-22-2005 14:40 |
Siemens X65 with slave Box | Amir-SkillZ | powerflasher | 15 | 05-02-2005 15:13 |
repair dead Siemens CM35 | ripper_bg | x1x to x45/x50 | 3 | 09-12-2001 22:39 |
