S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
04-23-2006, 09:19 | #61 (permalink) |
No Life Poster Join Date: Sep 2002 Location: GSM_land Age: 47
Member: 15217 Status: Offline Thanks Meter: 21 | when i am flashing it with V_klay after press refresh: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙ ˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙; Flash: ID1: 0x0089, Type1: 0x800D; IMEI "A haredware I/O error was reported while accessing com1-loader:Authorization#1:loader not ready" by x65PapuaUtils075e this message appear: Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... FlashID: 0089,800D Data of BootInfo are erroneous! €Á Ą * @* Information incorrect! HASH: 0580404602000000810008013C408A40 OTP ESN: 03F7DAF0 OTP IMEI: 100010009800?< Boot released. any one can help me to repair this phone |
04-25-2006, 13:43 | #64 (permalink) | |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | Quote:
First look here . It is the solution for you. Best regards, Aishur | |
04-26-2006, 08:23 | #65 (permalink) | |
Member: 15217 Status: Offline Thanks Meter: 21 | Quote:
Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... FlashID: 0089,800D Data of BootInfo are erroneous! €Á Ą @ Information incorrect! HASH: 0580404602000000810008013C408A40 OTP ESN: 03F7DAF0 OTP IMEI: 100010009800?< Write BCORE version: "main_1.0_V22 " Incorrect Information of Flash CFI! Error writing BCORE segment! Repeat Operation! | |
04-28-2006, 01:43 | #67 (permalink) |
Junior Member Join Date: May 2004 Location: Rostov Russia Age: 53
Member: 65946 Status: Offline Thanks Meter: 1 | First anyone has to do - remoove CPU and take a look at the printed board under it. CPU IC is very large, and not flexible, but board is flexible to some degree. Never seen corrupted flash IC or CPU IC, but distroyed wires under CPU... |
04-28-2006, 04:39 | #68 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
05-05-2006, 13:46 | #69 (permalink) |
No Life Poster Join Date: Sep 2004 Location: in AXE control room Age: 54
Member: 84300 Status: Offline Thanks Meter: 74 | Well, problem i have noone have ( except my bad english ) one cx65 working only on serial com cable !!!! Won't turn on , but when cable is pluged in, then start. and why otp is closed, i readed all keys,send key, all well, but when try freeze Code(05): OTP is Closed for writing! Code(0D): Keys are stored in BCORE! In this mode Freeze is impossible! and ... how to solve that : when try to write new bootcore Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... FlashID: 0089,884D CXv5@ SIEMENS s5s5t1p0q8v6u5s IMEI in BCORE is invalid! HASH: 79157F05DCCF78FBCEA36029F3DB66A3 OTP ESN: 2C7ABB83 OTP IMEI: 31353<00065957 It was BCORE version: "main_1n0_Vq8`" Write BCORE version: "main_1.0_V22 " Incorrect Information of Flash CFI! Error writing BCORE segment! Repeat Operation! and second phone, same error: Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... FlashID: 0089,884D CXv5@ SIEMENS s5s5t1p0x8x8r3x IMEI in BCORE is invalid! HASH: D4CE58DED9017673DB44466F5B79C2CC OTP ESN: 7348AD9D OTP IMEI: 313545008<8827 It was BCORE version: "main_1n0_Vq8`" Write BCORE version: "main_1.0_V22 " Incorrect Information of Flash CFI! Error writing BCORE segment! Repeat Operation WHAT i can do , or what should be next step in repair that phones ?? |
05-15-2006, 05:28 | #70 (permalink) |
Junior Member Join Date: Mar 2006
Member: 245017 Status: Offline Thanks Meter: 0 | I'm a Chinese boy,nice to communicate with you. My S65 was out fo work,the bootcore was cleaned by mistake! It can't connect with x65flasher and V_KLay. I used the testpoint to save it,but failed,x65PapuaUtils is still warning:wrong bkey or not use TP. i wonder what's the martech isolution and dreambox. could you give me a faver? thank you. if possible,send me any sotfware which can be used. thank you very much my Email add:[email protected] ICQ 286499219 |
05-15-2006, 19:07 | #71 (permalink) |
Freak Poster Join Date: May 2003 Location: Athens, Greece
Member: 29130 Status: Offline Thanks Meter: 5 | @Crumarix1 You certainly have a hardware problem !... Not only BootCore information has garbage... but also OTP IMEI has invalid character : '<' and even CFI Information is wrong ... Also Flash ID from Intel 884D does not exist... only 880D! So either rehot or resolder or replace Flash IC with a brand new one ... No software - firmware method could fix that... OTP is always closed on used Flash ICs. Only on brand new could be open... (One Time Programmed : OTP ... you got one chance !) |
08-02-2006, 04:35 | #74 (permalink) |
Junior Member Join Date: Mar 2004 Age: 51
Member: 56577 Status: Offline Thanks Meter: 0 | anybody knows whats wrong with this one? Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... FlashID: 0001,227E (32Mb) ...(amd) C72V SIEMENS 357364002319084 HASH: 794E55362CBB2B14A90B8CAD39BA15C4 OTP ESN: CDC04A47 ? OTP IMEI: Not recorded or incorrect! Boot released. and when entering skey..... Boot in "Service mode" Ok Awaiting Power On phone... Getting Information: Model: SIEMENS C72 20 lg1 Phone is in "Service Mode" mode IMEI: 357364002319084 SecurityStatus: CustomerMode HWID: 5005 Attention: Charge Accumulator! Accumulator Voltage: 3678 mV. Checking values entered... Test "Service key" (SKEY)... Sending "Service key"(SKEY) to the phone... SKEY entered! Pause 1 second(s)... SecurityStatus: CustomerMode Checking values entered... Block EEP76 saved. Cannot create block EEP5008! |
can i repair dead siemens m65 with furious?? | hamada33r | FuriousGold | 6 | 04-30-2008 21:17 |
Repair Dead BE4 BE5 WITH DEAD TEH | chip_2000 | Alcatel & TCL Old Models | 25 | 10-23-2005 09:18 |
K750 dead.... can anyone explain more detail?? | PhoneDeal | SonyEricsson (USB-Smart) | 7 | 08-22-2005 14:40 |
Siemens X65 with slave Box | Amir-SkillZ | powerflasher | 15 | 05-02-2005 15:13 |
repair dead Siemens CM35 | ripper_bg | x1x to x45/x50 | 3 | 09-12-2001 22:39 |
