S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
11-09-2006, 15:08 | #1 (permalink) |
Junior Member Join Date: Sep 2006
Member: 353942 Status: Offline Thanks Meter: 0 | S66 / S65 help I fully charged battery and successfully unlocked the phone. I put an orange sim card in the phone and everything was fine. I then unplugged USB cable and phone turned off and refused to turn on again. Screen flashes white for a fraction of a second but that is all. Very occasionally it will work OK for 5 minutes or so then switch off again (though 95% of the time it just won't switch on). However it will happily switch on and works perfectly if it is plugged into a charger or a USB cable. I take it that this is a hardware fault rather than anytrhing that could be cured by flashing - am i correct? Many thanks for any help or advice you can give me. Best wishes - Ian P.S - it does the same with 3 different fully charged batteries which work fine in my SP65 so obviously not a battery problem |
S65 - help unlock my phone (3x wrong input) | Munich_82178 | S-Gold Based Phones | 3 | 01-09-2009 05:25 |
Unlock my s65/s66 v34? | ozziegt | S-Gold Based Phones | 5 | 12-04-2005 19:49 |
S65 Help | eggwisher | S-Gold Based Phones | 3 | 11-08-2005 17:44 |
Is It Possible To Flash S66 With S65 Winswup Flash File!? | KUBAT1 | S-Gold Based Phones | 1 | 04-28-2005 15:42 |
S65 Help Needed | ferd32 | S-Gold Based Phones | 2 | 12-27-2004 14:04 |
