S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
01-03-2009, 09:24 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
-connect the service cable, open papuautils and go to the "Flash" menu. NOT PUSH TO POWER ON BUTTON NOW!!! -check only "??????OTP", "Recalculate Keys" (all 4 options) and "Pause". -make testpoint, click on "Do the Job!", push shortly power on button and see on the right windows from papua. -disconnect testpoint (see message - you have three secconds...) and wait to finished. Be carrefully, in the unlocking process you have one pause with somme secconds between reading and writing eeprom blocks. Not disconnect!!!! Maybe after this your HASH will be FFFFFFFFFFFFFF, not important. Appeare because SKEY is forced with 12345678 combination (tipically because you force unlocking with testpoint).... dagos | |
01-05-2009, 16:35 | #3 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 48
Member: 184973 Status: Offline Thanks Meter: 27 | help cx65 hello mr dagos i have tried as you say in the post but it still the same .see papua log Boot not loaded! Boot released. Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... Correctly release TestPoint! Boot released. Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... Correctly release TestPoint! Boot released. Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... FlashID: 0089,880D (32Mb) BCORE Cleared! OTP ESN: 572D9399 OTP IMEI: 353538009051964 Test data bus D0..D15...OK. Test address bus A2..A22...OK. Bcore R65 series found Search of a segment EELITE... Search of a segments EEFULL... Find blocks: 52,76,5008,5009,5077,5121,5122,5123 In total EEP blocks: 233 EEPROM Blocks saved in .\Backup\572D9399_EEP_090105182937.eep Boot released. Everything is closed.! Calculation of keys... Keys calculated successfully: BootKEY: 0B41DA33DBC341B950BB1F9D0B5051A0 SKEY: 84211256 Checking values entered... Calculate HASH and BootKEY from ESN and SKEY... New HASH: D04494F3B25D30CDDD7276A4F1283279 New BootKEY:0B41DA33DBC341B950BB1F9D0B5051A0 Checking values entered... Calculate HASH and BootKEY from ESN and SKEY... New HASH: D04494F3B25D30CDDD7276A4F1283279 New BootKEY:0B41DA33DBC341B950BB1F9D0B5051A0 Checking values entered... Calculate HASH and BootKEY from ESN and SKEY... New HASH: D04494F3B25D30CDDD7276A4F1283279 New BootKEY:0B41DA33DBC341B950BB1F9D0B5051A0 Checking values entered... Test "Service key" (SKEY)... Sending SKEY/BKEY to the phone... Phone was switched off on error: EXIT: 0002:9ECC FILE: imei CPSR: 60000030 CepId: FFFF No answer from the phone Check port number, cable, phone, mode! |
01-05-2009, 20:05 | #4 (permalink) | |
Remain to flash your phone using good fullflash (included bootcore area) or only bootcore part and unlock again using presented steps. To flash with bootcore, use MS-DOS command "x65flasher /b" . Use testpoint to connect with x65flasher software! dagos | |
01-09-2009, 12:00 | #7 (permalink) | |
-unrar X65flasher archive in the root of C drive or D drive. -rename this folder with x65flasher name. -if you use Windows XP, click on Start-> Run and type -> cmd MS-DOS prompter will be opened. Type here the following commands: C: (if you extract in the C drive root) or D: (if you extract in the D drive root). Push on the "Enter" taste after. cd x65flasher Push on the "Enter" taste after. x65flasher /b Push on the "Enter" taste after. Now is oppened the x65flasher window with the writing bootcore option enabled... That is... dagos | |
01-22-2009, 09:41 | #8 (permalink) | |
Member: 184973 Status: Offline Thanks Meter: 27 | help cx65 Quote:
01-22-2009, 15:31 | #10 (permalink) | |
dagos Last edited by dagos; 03-27-2010 at 04:10. | |
plz help cx65 blue display | tenderprince | Siemens Hardware Repair Area | 7 | 07-26-2005 19:04 |
Help Cx65 White Display | Kingrim | Siemens Hardware Repair Area | 3 | 05-27-2005 12:46 |
plz help cx65 blue lcd | tenderprince | S-Gold Based Phones | 2 | 04-01-2005 23:06 |
