Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2006 Location: Munyanja
Member: 279790 Status: Offline Sonork: icq: 648661016 Thanks: 44
| siemen C75 wrong software after unlock with x65PapuaUtilsV079c "Following steps by Amir- Skillz Many of US know this If u r one of them Dont say its OLD or ELSE dont read THIS..... Hope u understand Admin Posted on net offcourse We all Learn from SomeWhere....So..i am just Making Easy for NewBees >>>>>>>>>>>>>>We Need<<<<<<<<<<<<<<<<<<< A phone of Sgold Platform...Offcourse Locked and any Version Who Cares.... Need Orignal Data Cable DCA500 DCA510 and Siemens Phone Manager ....like SiMoCo and other....... So Here We Go... First of All Connect ur Mobile (with Orignal Data Cable)and After Installing its Drivers now open its Folder Data/Applications........Now here Copy the File at my First Post Amir-SkillZ that Java Midlet. HERE http://www.mobile-files.com/forum/sh...ad.php?t=25160 SO ..... Confirm Local Connection "by Session" ....oK And Must Confirm Access Application Java to Data Cable....(main Thing OK) NOW........WAIT about 5Minutes (As old midlet u have to wait Longer But this 1 is Fast) When u heared a Beep u Will see the IMEI ESN HasH on Phone (yes U r going Right) DO NOT TOUCH ANYTHING REMEMBER And Run the X65Flasher (any Version) Click on Connect and wait for Keys Calculation is Started When DONE....NOW RUN X65Papus Utilities....any version u got and CLick the Button PX65V4 at Codes TAB........ What Happened The Soft now Started the recieving of codes IMEI ESN HASH from Phone (Java Application) ...Now CLick "Calculate Skey and Bkey " and Wait to be Bkey Calculated..... Turn off Ur Phone Now ...Click the Service Mode....And then click on Main Button "Enter Skey Into Phone" All Keys are saved Now..... NOW DC the data Cable and Connect the Unlock Cable of X65 series Again With papuas Make ur Mobile into Service Mode.....click on Enter Skey in Phone ....There Must be Appeared "Factory MODE" (At Papuas Screen) .OK Now CLick FreiaLOG when it ask to save Cancel it And it will Ask u to Write Directly on Mobile Click YES..It will Write Block....And GUESS WHAT UR PHONE IS UNLOCK WIHTOUT OPENING ***********Thankx to SM4RTBOY for His HELP*************** WBR Amir34 Love from PAKISTAN to ALL Mobile-Files Members " __________________ I got wrong software after unlock and here is my log: Boot in "Service mode"... Press RED key (Power ON)! Auto Ignition... Boot not loaded! Phone is in "Format disks?" mode! Boot in "Service mode"... Press RED key (Power ON)! Auto Ignition... No answer to boot load! Check port number, cable, phone, mode! Boot in "Service mode"... Press RED key (Power ON)! Auto Ignition... No answer to boot load! Check port number, cable, phone, mode! Boot in "Service mode"... Press RED key (Power ON)! Auto Ignition... No answer to boot load! Check port number, cable, phone, mode! Boot in "Service mode"... Press RED key (Power ON)! Auto Ignition... Boot not loaded! Phone is in "Normal Mode" mode! Phone is Turned Off... Try again. Boot in "Service mode"... Press RED key (Power ON)! Auto Ignition... No answer to boot load! Check port number, cable, phone, mode! Boot in "Service mode"... Press RED key (Power ON)! Auto Ignition... No answer to boot load! Check port number, cable, phone, mode! Boot in "Service mode"... Press RED key (Power ON)! Auto Ignition... Boot not loaded! Phone is in "Normal Mode" mode! Phone is Turned Off... Try again. Boot in "Service mode"... Press RED key (Power ON)! Auto Ignition... Transfer boot... Boot in "Service mode" Ok Awaiting Power On phone... Getting Information: Model: SIEMENS C75 22 lg2 Phone is in "Service Mode" mode IMEI: 356270006893753 SecurityStatus: CustomerMode HWID: 341 Attention: Charge Accumulator! Accumulator Voltage: 3675 mV. Checking values entered... Test "Service key" (SKEY)... Sending is stoped! Checking values entered... Test "Service key" (SKEY)... Sending is stoped! Checking values entered... Calculate HASH and BootKEY from ESN and SKEY... New HASH: 4A6663CF4798CC94163D553C9EDD2AFC New BootKEY: 35327DEAF3D5D2205D97F376822F7862 Calculation of keys... Keys calculated successfully: BootKEY: 35327DEAF3D5D2205D97F376822F7862 SKEY: 99840312 Checking values entered... Calculate HASH and BootKEY from ESN and SKEY... New HASH: 4A6663CF4798CC94163D553C9EDD2AFC New BootKEY: 35327DEAF3D5D2205D97F376822F7862 Checking values entered... Test "Service key" (SKEY)... Sending "Service key"(SKEY) to the phone... SKEY entered! Pause 1 second(s)... SecurityStatus: FactoryMode Checking values entered... Block EEP76 saved. Block EEP5008 saved. Block EEP5009 saved. Block EEP5077 saved. Blocks were written to phone. |
| | #2 (permalink) |
| Moderator ![]() Join Date: Dec 2006
Member: 416908 Status: Offline Thanks: 3
| ...... just fullflash your phone with good fullflash file, using X65 flasher and unlock it after with papuautils 1.1.1c, First step is to generate config.ini file with papuautils and save it in the X65flasher root directory. Without this, you not be able to working with X65flasher software. dagos |
| | #3 (permalink) |
| I solved my problem by re-unlocking using this procedure and i think problem came about entering ESN in PapuaUtils but whoever finds a problem follow these steps on this link: http://freefonesoftware.co.uk/index....=s-gold-models |
| The Following User Says Thank You to Jayrus For This Useful Post: |
| | #4 (permalink) | |
| Quote:
if use DCA510 (modifyed) cable, not needed to write manually ESN and HASH. Just click on "PX65V4" button (after you have this codes on the phone display) and automatically is saved in Papua. dagos | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| CF62 indicates WRONG SOFTWARE after unlocking with SST | gancellshop | Siemens Hardware Repair Area | 7 | 06-17-2006 03:56 |
| CX 70 Wrong Software after unlock with SWAP | khawar | SWAP | 0 | 09-08-2005 16:25 |
| A65 Wrong Software After Unlock With SST5.38 | flechazo | E-Gold Based Phones | 23 | 07-27-2005 19:33 |
| MC60 Wrong Software after unlocking | alhaddare | E-Gold Based Phones | 1 | 08-30-2004 15:07 |
| C45 v06 Wrong Software after unlock with x45 software cracked | VendorGSM | x1x to x45/x50 | 1 | 04-10-2002 09:02 |
