S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
09-09-2005, 09:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2003
Member: 21553 Status: Offline Sonork: 100.114141 Thanks Meter: 220 | C65 new probleme and Big problem when i flash the handset said flash type not supported. I rehot the flash IC probleme is always the same. I use martech Box plz I need some help |
09-09-2005, 09:51 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: TelServisHalo,Loznica, Serbia Age: 53
Member: 21365 Status: Offline Thanks Meter: 92 | If Martech say.. ..that Flash IC is not supported, than take the Flash IC and look good(with microscope) on PCB contacts. If they are OK, than change Flash IC and IMEI U can change with proper free tool, and by way dicrabed on the forum(just use search1) Cheers |
09-09-2005, 10:06 | #3 (permalink) |
Member: 21553 Status: Offline Sonork: 100.114141 Thanks Meter: 220 | thx m8 but don't forget it's V41 we need test point and I have just test point with martech but can't change imei alwayes not supported ....I trayd with sst craked with the same test point but not work. |
09-10-2005, 14:22 | #6 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Cochabamba Age: 38
Member: 87396 Status: Offline Thanks Meter: 64 | it testpoint is damaged you need to remake it (by damaged i understand that cannot see the point) to repair this phone you have to replace flash ic theres no other wayi had 2 of this and could do nothing else |
new and big problem N95 8gb | the jinnah | Nokia Base Band 5 ( BB-5 ) | 1 | 08-09-2009 12:19 |
W880i-CID53 new unlock java big problem | Nurettin Duman | SETool2 | 0 | 10-14-2008 20:02 |
New User have big problem!! | rabbito | Smart-Clip | 1 | 09-27-2006 08:21 |
C65 new probleme and Big problem | riadh_tn | SIEM Service Tools | 10 | 07-14-2006 13:32 |
