Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 08-26-2005, 00:23   #1 (permalink)
Member: 43094
Simple CF62T Question..
I've a CF62T locked to the T-Mobile USA network. In order to remove the T-Mobile branding I was told to flash a different FW version to it, however the update was "denied" by the phone using WINSWUP. If I get an unlock code and unlock my phone will I be able to remove the branding then with WINSWUP?
I'd rather not mess with testpoints.
Old 08-28-2005, 01:50   #2 (permalink)
Crazy Poster
Member: 7612
Thanks Meter: 9
Only testpoint,then fullflash downgrade with freia (for example),then correct swup with your lang.And ffs if you wish
It's only way to unbranding.
Old 08-28-2005, 16:00   #3 (permalink)
Chris02's Avatar
Member: 41076
Thanks Meter: 53
You forgot to write the Map file
Old 08-28-2005, 18:00   #4 (permalink)
Member: 43094
Alright, thanks for the help. I'll see what I can accomplish with my trusty Torx.
Old 08-30-2005, 15:56   #5 (permalink)
Member: 43094
I've succesfully cut the testpoint, but when I tried downgrading with WINSWUP it said no bootcore present.
I presume I should get a CF62 fullflash, flash it to the phone and then downgrade the SW (unlocking then with sw11)? Would I be able to use V_KLay for this or should Freia be used?
Old 08-30-2005, 20:30   #6 (permalink)
Crazy Poster
Member: 7612
Thanks Meter: 9
You can use freia,set phone as m55,after flashing- repair imei,then swup.
Old 09-01-2005, 18:49   #7 (permalink)
Member: 43094
I just cut the TP, used SST with the unlock option - and it accepted my O2 Ireland sim with no problems. The left soft key was set to T-Zones only with my T-Mobile sim but with my O2 one I can set it to anything I want.
Thanks for the help
simple BB question sammylola BlackBerry (RIM) 0 03-11-2009 10:55
T68 simple flash question bufny Sony Ericsson 0 06-14-2006 20:55
Simple question, please simple answer regarding A920 peshta Motorola P2k 0 05-04-2005 00:26
Simple A300 question tchavei VLSI, Conexant, Skyworks and Old Models 0 11-16-2001 19:40
Page generated in 0.35926 seconds with 8 queries
