S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
04-24-2006, 02:27 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2002 Location: Tunisia Age: 45
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | **sl65 only beep** br |
04-24-2006, 16:04 | #5 (permalink) |
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | thanks bro the pswd is working now but everytime i try to flash i got erase error at the same adress !! should i rehot flash ship? the problem is that with swup i can flash it normally? br |
04-24-2006, 16:22 | #6 (permalink) |
No Life Poster Join Date: Jul 2004 Location: GEORGIA,Tbilisi
Member: 75765 Status: Offline Thanks Meter: 722 | @ infogsm Write more details about your problems ! What soft are you using for flashing ? To know, maybe you dont need to rehot FlashIC I dont think SWUP will fix it, but fullflash converted to SWUP with original keys of phone will ! |
04-24-2006, 19:22 | #7 (permalink) |
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | ok now i got phone in test mode and when i read phone with TP it has diffrent imei and hash (because of written eeprom) and i can't calculate new skey or change imei !! i used old skey but don't work !! for flashing i used x65flassher and vklay !! AutoIgnition... Transmit Boot... Boot loaded ... Pause 2 sec... Retrieve information... FlashID: 0089,880D SIEMENS SL65 354220004214918 HASH: DF039DC53B2322FF6B9B950F968DC7DE OTP ESN: DB1186B9 OTP IMEI: 354220006396283 All EEP blocks: 197 Not found block76! Not found block52! Boot unllock. Exist someth.! Calculate KEYS.. Key not found ! help needed! br |
04-24-2006, 22:57 | #10 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Athens - Greece
Member: 59935 Status: Offline Thanks Meter: 131 | @infogsm You have : OTP ESN: DB1186B9 OTP IMEI: 354220006396283 So you can enter "own" skey "12345678" After that there is a button "Recalc HASH and BootKey from ESN and SKEY" Sorry i'm usin a RUSSIAN ver so maybe some similar .... After that you can send SKEY into phone ... Try it. Papuas is very flexible program All operations in SERVICE MODE. BR |
04-25-2006, 01:18 | #11 (permalink) | |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | Quote:
04-25-2006, 01:32 | #12 (permalink) |
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | i have all the original data back(skey+imei) but still same problem !! i think i have a problem with eelite and i'm unable to write full flash with x65flasher or vklay3.3! !! always stops in same adress!! br |
04-25-2006, 01:50 | #13 (permalink) |
Member: 111457 Status: Offline Thanks Meter: 967 | try in Flash Tab, check pause & Replace 67,5008..... then use these value and make a swap flasher like video tuturial posted by BB-gsm IMEI: 354220006396283 ESN: DB1186B9 HASH: 95531C9E9BB01B45926AAFF420E8ACE6 SKEY: 12345678 BKEY: 11855ECE1545C84A4C1C675DE98254BF HWID: 324 maybe can help |
04-25-2006, 07:48 | #14 (permalink) |
Member: 75765 Status: Offline Thanks Meter: 722 | I did not post any video tutorial, Watch tutorial from Papuas site and follow it ! If flashing stops again at the same adress, then resolder Flash IC ! Regards, B |
04-25-2006, 11:50 | #15 (permalink) |
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | the flash ship is damaged is it possible to read it and not write? cause i can read the hole flash without problem !!but when writing i always get that erase error at adress 004E000 !!! is there a flasher that can skip bad adresses ? br |
Nokia 1255 show only bettery . | sonu arya | Nokia CDMA | 8 | 05-07-2010 18:47 |
Only on SUNDAY and only in this thread!!! "DCT4 CODES FREE FOR ALL!!!" | Winner58 | Phone Unlocking Codes & Maps | 141 | 03-31-2003 00:25 |
for only 48 hour only a800 arabic flash freeeeeeeeeeeeeeee | fonec | VLSI, Conexant, Skyworks and Old Models | 15 | 03-28-2003 02:24 |
Only on SUNDAY and only in this thread!!! "DCT4 CODES FREE FOR ALL!!!" | Winner58 | Phone Unlocking Codes & Maps | 209 | 03-24-2003 07:38 |
Only on SUNDAY and only in this thread!!! "DCT4 CODES FREE FOR ALL!!!" | Winner58 | Phone Unlocking Codes & Maps | 287 | 03-17-2003 19:00 |
