Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 07-26-2008, 17:28   #1 (permalink)
Member: 146708
Sonork: 100.108221
SL75 IMEI Rebuild...
hi all...
after writing patched eeprom phone is bip..abyone has testes patch area..? anyone has change the imei of sl75..?
Old 07-26-2008, 18:33   #2 (permalink)
Member: 146708
Sonork: 100.108221
Originally Posted by LoveLess View Post
hi all...
nobody has any idea..?
Old 07-27-2008, 05:52   #3 (permalink)
Moderator
dagos's Avatar
Member: 416908
...this is writed by trixxi3:
STEP by STEP of X65 Imei Change by Trixxi3
First of all some aclarations:
- This works on phone versions <36
- After this you canīt upgrade with WSUP/Update
- After this you canīt unlock with any soft
- After this you can change ffs
Correct way.
1 - Downgrade with any way to <36 version.
2 - Open x65PapuaUtilsV038d_ENG.exe, Press "Service Mode"
3 - Go to "Codes" and press "Auto Open All"
4 - Go to "Flash", mark "Pause" and "New BCore V22"
5 - Press "Do Job" and wait for finish.
6 - Turn Off mobile if not auto off.
7 - Go to "Settings" and press "Service Mode"
8 - Go to "Flash" and mark "Recalculate Keys in Flash" (two more options will be auto mark, all itīs ok)
If any advice of Wrong entry appear return to codes section and fill Skey and Bkey with any numbers.
9 - Press "Do Job" and wait for finish.
10 - Go to "Settings" and press "Service Mode"
11 - Go to "Codes" and press "Auto Open All"
12 - Press "Freia.log" and save file with any name, but remember this name later
13 - Press "x65flasher.ini" and save file in x65flasher dir.
14 - Open x65flasher.exe and Press "Connect"
15 - Change "Leght" to 40000 and Press "Read Flash", save file
16 - Open SSWx65.exe and write your ESN, calculated by Papuas, Inverted in "Phone Id"
EX: In codes section of Papuas you get ESN: A1B2C3D4, then write in "Phone Id" of
SSWx65.exe in this way: D4C3B2A1.
17 - Write new imei in "New phone Imei" and Press "Dissable OTP", select file saved in step 15.
18 - Save file.
19 - Open x65flasher, select Leght to 40000 and Press "Write Flash", select file saved in step 18.
20 - Press OK to Skip Write BCore confirmation.
21 - Open mapper.exe, select log file saved in step 12, write imei of step 17, MUST TO BE THE SAME!
22 - Open x65PapuaUtilsV038d_ENG.exe, Press "Service Mode", Go to "Codes" and press "Enter Skey in Phone"
23 - In right window must see "Telephone in Factory Mode"
24 - Open Siemens EEPROM tool.exe, Press "Init", Press "Load" and select map file saved in step 21, Press "Select All" in left side, Press Right Arrow, Press "Select All" in right side, Press "Save Selected".
25 - Turn OFF your mobile, and turn ON again for confirmation of new Imei.
GOOD LUCK.
PS: Sorry my bad english.
Thx to any person involved in development of all soft included in this Step by Step.
WBR Trixxi3
and download from http://rapidshare.com/files/132754632/x65imei.rar
I have only one question: Whay more persons try to change the phone IMEI?
dagos
Old 07-27-2008, 22:27   #4 (permalink)
Member: 146708
Sonork: 100.108221
Correct way.
18 - Save file.
GOOD LUCK.
WBR Trixxi3
dagos
cause phoenes are in blacklisted.. blocked by our good gov..
i done it sir.. but after last step...writing eeprom... phone is not power on... only bip..
Old 07-27-2008, 23:32   #5 (permalink)
paullovinicius's Avatar
Member: 164786
I think you not clicked in "Save Selected" and clicked in the other button, i don't remember but i think it's "Save All".
Now you need to restore eeprom backup.
Other tip is try to use an older version possible.
Old 07-28-2008, 16:39   #6 (permalink)
Member: 146708
Sonork: 100.108221
thanx for ur reply... i really done it.. save selected.. and phone sw is 13.. i think it hasnt lower sw..
Old 07-28-2008, 17:00   #7 (permalink)
Moderator
dagos's Avatar
Member: 416908
..SW13 is the SL75 lower version.
dagos
Old 07-29-2008, 16:11   #8 (permalink)
Member: 146708
Sonork: 100.108221
still bip bip bip..
nobody has any idea about x75 patch..?
6230 Imei ???..?-rebuild Imei Ok Using Logs-again Set Off zone2 MT-BOX 5 02-03-2008 05:51
Is IMEI rebuild will change the imei on network? kiklop07 HWK 8 10-22-2007 23:17
Is IMEI rebuild will change the imei on network? kiklop07 UFS2 + UFS3-Tornadoflasher 0 10-21-2007 12:38
Is IMEI rebuild will change the imei on network? kiklop07 UST Pro II 0 10-21-2007 11:51
does it possible to chnage imei on 2100 witj griffin dct3 dct4 imei rebuild ? GYZMO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 29 05-06-2005 06:18
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.29832 seconds with 10 queries
