Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 07-25-2008, 16:29   #1 (permalink)
Member: 146708
Sonork: 100.108221
SL75 Totaly Dead...
hi all..
phoe was working fine.. i tryo change imei.. after steps (given on he forum) phone not power on.. only bip..and now phone is totaly dead..
pls check log...
Getting Information:
Model:SIEMENS SL75 13 lg1
Phone is in "Service Mode" mode
IMEI:000000000000
SecurityStatus:CustomerMode
HWID:411
Accumulator Voltage: 3964 mV
Old 07-25-2008, 16:49   #2 (permalink)
Moderator
dagos's Avatar
Member: 416908
Originally Posted by LoveLess View Post
hi all..
pls check log...
IMEI:000000000000
HWID:411
...uff,
again IMEI patch...
Open papuautils, go to Flash menu, check only: Pause; ??????OTP and Recalculate Keys. Do the Job and wait. Normarly is neded to put again the OTP IMEI. If not working, remain to use this steps, but with testpoint option.
BTW: your phone need to be OFF (without Service Mode).
dagos
Old 07-26-2008, 09:53   #3 (permalink)
Member: 146708
Sonork: 100.108221
Originally Posted by dagos View Post
...uff,
again IMEI patch...
dagos
sir...
recalculate keys are no working...
Old 07-26-2008, 09:59   #4 (permalink)
Member: 146708
Sonork: 100.108221
...uff,
again IMEI patch...
dagos
imei is correct now.. i have backup...after backup phone is again normally..but again only bip... i think pb is eeprom...cause after writing patched eeprom phone dead..
Old 07-26-2008, 12:26   #5 (permalink)
Member: 146708
Sonork: 100.108221
...uff,
again IMEI patch...
dagos
Auto Ignition...
Transfer boot...
BOOT is loaded...
Pause 2 sec...
Getting Information...
FlashID: 0089,880D (64Mb) ...(Intel)
BCORE clean!
OTP ESN: 47A7F043
OTP IMEI: 357017001886152
Not found segment EEFULL!
Working with BCORE...
Phone requires Freeze!?
when i have try to freeze phoene gives error...
Model: SIEMENS SL75 13 lg1
SecurityStatus: FactoryMode
HWID: 411
Attention: Not matching HWID and Phone model!
Model expected : hw_SL75, but received : SL75 !
Bcore model area is clean !!!
Accumulator Voltage: 3975 mV.
Checking values entered and necessary blocks...
Impossible to get Security information!
Old 07-26-2008, 12:58   #6 (permalink)
Moderator
dagos's Avatar
Member: 416908
Auto Ignition...
Transfer boot...
BOOT is loaded...
Pause 2 sec...
BCORE clean!
OTP ESN: 47A7F043
HWID: 411
...don't try to freeze!
Please give to me the actual log file (enter in Service Mode) to see what is happened.
dagos
Old 07-26-2008, 13:14   #7 (permalink)
Member: 146708
Sonork: 100.108221
dagos
oki sir... pls wait for me... flashing now...
Old 07-26-2008, 13:19   #8 (permalink)
Moderator
dagos's Avatar
Member: 416908
...I hope to you flash without bootcore area
dagos
Old 07-26-2008, 13:27   #9 (permalink)
Member: 146708
Sonork: 100.108221
dagos
i used this flash file sir..
SL75_new_24.bin
Old 07-26-2008, 13:35   #10 (permalink)
Member: 146708
Sonork: 100.108221
SL75_new_24.bin
after this flash phone is again bip..and service mode log...
Model: SIEMENS SL75 24 lg91
Phone is in "Format FFS?" mode
SecurityStatus: CustomerMode
HWID: 411
Accumulator Voltage: 3913 mV.
Old 07-26-2008, 13:51   #11 (permalink)
Moderator
dagos's Avatar
Member: 416908
HWID: 411
...hmmm,
first, you used fullflash with 64MB (blank)
second, after patch IMEI, you reconfigurate the bootcore area.
Try again to use: "Open papuautils, go to Flash menu, check only: Pause; ??????OTP and Recalculate Keys. Do the Job and wait. " and give me the log file.
dagos
Old 07-26-2008, 13:56   #12 (permalink)
Member: 146708
Sonork: 100.108221
...hmmm,
dagos
Auto Ignition...
Transfer boot...
BOOT is loaded...
Pause 2 sec...
BCORE clean!
OTP ESN: 47A7F043
Old 07-26-2008, 14:02   #13 (permalink)
Moderator
dagos's Avatar
Member: 416908
...Ok,
In the future use x65PapuaUtilsV111b.
Which program you used to flash your phone?
Old 07-26-2008, 14:04   #14 (permalink)
Member: 146708
Sonork: 100.108221
...Ok,
flasher sir..
thanx..
Old 07-26-2008, 14:10   #15 (permalink)
Member: 146708
Sonork: 100.108221
...Ok,
again bip sir..
FlashID(3) - Manufact. code:0089 (Intel), type: 881C. DisplayID(1,59): Epson L2F50333T.
Checking value of SKEY from page "Codes"...
Auto Ignition...
Transfer boot...
BOOT is loaded...
Pause 2 sec...
BCORE Cleared!
OTP ESN: 47A7F043
Bcore S/SL75 found
Reading of segment BCORE...
BCORE segment are kept in 47A7F043_A0000000_BCORE_080726160723.bin
Search of a segment EELITE...
Search of a segments EEFULL...
Find blocks: 52,76,5008,5009,5077,5121,5122,5123
In total EEP blocks: 144
EEPROM Blocks saved in .\Backup\47A7F043_EEP_080726160757.eep
Replacement of blocks EEPROM in the buffer ...
EEPROM: Block 76 replaced.
EEPROM: Block 52 replaced.
EEPROM: Block 5122 replaced.
EEPROM: Block 5009 replaced.
EEPROM: Block 5008 replaced.
EEPROM: Block 5077 replaced.
EEPROM: Block 5121 replaced.
New Master codes:
*#0000*12345678#
*#0001*12345678#
*#0002*12345678#
*#0003*12345678#
*#0004*12345678#
*#0005*12345678#
EEPROM: Block 5123 replaced.
BCORE "Cleared", recalculation impossible
Record of the changed blocks in phone...
Write down EEPROM segments...
EEPROM segments write down.
Boot released. Everything is closed.!
warning T205 totaly dead after flashing!!! al_bu2000 ODM (Original Design Manufacturing) 2 11-09-2001 07:56
Solution for totaly dead Alcatel db guiso Alcatel & TCL Old Models 0 08-29-2001 21:37
8210 totaly dead ,,hardware misel Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-06-2001 20:57
Help 8210 - 5.26 totaly dead Demon_Ok Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 04-22-2001 20:02
Alcatel BE4 Totaly Dead (hardware problem) d2cards Alcatel & TCL Old Models 0 04-22-2001 12:00
Page generated in 0.45439 seconds with 12 queries
