Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 06-10-2005, 19:21   #1 (permalink)
Member: 13748
STEP by STEP of X65 Imei Change by Trixxi3
Preliminar:
- This works on phone versions <36
- After this you canīt upgrade with WSUP/Update, youīll lose your new imei.
- After this you canīt unlock with any soft, youīll lose your new imei.
- After this you can change ffs.
Correct way.
1 - Downgrade with any way to <36 version.
2 - Open x65PapuaUtilsV038d_ENG.exe, Press "Service Mode"
3 - Go to "Codes" and press "Auto Open All"
4 - Go to "Flash", mark "Pause" and "New BCore V22"
5 - Press "Do Job" and wait for finish.
6 - Turn Off mobile if not auto off.
7 - Go to "Settings" and press "Service Mode"
8 - Go to "Flash" and mark "Recalculate Keys in Flash" (two more options will be auto mark, all itīs ok)
If any advice of Wrong entry appear return to codes section and fill Skey and Bkey with any numbers.
9 - Press "Do Job" and wait for finish.
10 - Go to "Settings" and press "Service Mode"
11 - Go to "Codes" and press "Auto Open All"
12 - Press "Freia.log" and save file with any name, but remember this name later
13 - Press "x65flasher.ini" and save file in x65flasher dir.
14 - Open x65flasher.exe and Press "Connect"
15 - Change "Leght" to 40000 and Press "Read Flash", save file
16 - Open SSWx65.exe and write your ESN, calculated by Papuas, Inverted in "Phone Id"
EX: In codes section of Papuas you get ESN: A1B2C3D4, then write in "Phone Id" of
SSWx65.exe in this way: D4C3B2A1.
17 - Write new imei in "New phone Imei" and Press "Dissable OTP", select file saved in step 15.
18 - Save file.
19 - Open x65flasher, select Leght to 40000 and Press "Write Flash", select file saved in step 18.
20 - Press OK to Skip Write BCore confirmation.
21 - Open mapper.exe, select log file saved in step 12, write imei of step 17, MUST TO BE THE SAME!
22 - Open x65PapuaUtilsV038d_ENG.exe, Press "Service Mode", Go to "Codes" and press "Enter Skey in Phone"
23 - In right window must see "Telephone in Factory Mode"
24 - Open Siemens EEPROM tool.exe, Press "Init", Press "Load" and select map file saved in step 21, Press "Select All" in left side, Press Right Arrow, Press "Select All" in right side, Press "Save Selected".
25 - Turn OFF your mobile, and turn ON again for confirmation of new Imei.
GOOD LUCK.
PS: Sorry my bad english and thx to all people involved in development of all aplications used in this Step by Step.
WBR Trixxi3
The Following 4 Users Say Thank You to Trixxie For This Useful Post:
Old 06-16-2005, 18:16   #2 (permalink)
Cell-Manager's Avatar
Member: 120932
Wink
Hello to all, the same software q is for the change of IMEI of the C65 it will also be good me for the same thing in the C66?
The Following User Says Thank You to Cell-Manager For This Useful Post:
Old 06-16-2005, 18:30   #3 (permalink)
Murat Bekar's Avatar
Member: 2088
Sonork: 100.1630154
you have described the whole operation in 25 steps but it takes approx 3 minutes to do it but after some practicing
also without using papuasutils.
Regards
The Following User Says Thank You to Murat Bekar For This Useful Post:
Old 06-16-2005, 18:31   #4 (permalink)
maxijazz's Avatar
Member: 93787
i will try it at weekend.thnx for sharing..
regards;
maxijazz
Old 06-16-2005, 18:36   #5 (permalink)
Member: 53528
Can you tell me, is this solution change that IMEI, who is sent to GSM network or only visible IMEI seen as *#06#.
Old 06-16-2005, 19:41   #6 (permalink)
Member: 13748
Cell-manager: I have not tried in C66 , but I think youīll havenīt problems.
surfman: both!
Good luck and best regards.
Old 06-16-2005, 20:25   #7 (permalink)
Member: 58697
100% works on c65
and it's simpe
10x Trixxie
Old 06-16-2005, 20:30   #8 (permalink)
japunlock's Avatar
Member: 87396
tested on c66
it works but no need for me just for practicing
Old 06-28-2005, 00:16   #9 (permalink)
dickwredniak's Avatar
Member: 71669
i tested today on c65 v25 - work ok Thanx Trixxie!
Old 06-29-2005, 10:24   #10 (permalink)
thecult's Avatar
Member: 9700
great Trixxxie , good info
next task... we only have to decode tochogordo1 and tochogordo2
see u
Old 06-29-2005, 11:27   #11 (permalink)
Member: 13748
HEHEHEHEHEHEHEH!
Thatīs right. Still undecoded? did you leave that investigation?
Best regards.
Old 06-29-2005, 11:46   #12 (permalink)
thecult's Avatar
Member: 9700
still in project trixxie! we have developed few apps for doing it more easy, next time we talk I will explain u ... but this project will finish, sure.
nice to see u
Old 06-30-2005, 06:45   #13 (permalink)
Member: 5242
Many thx Trixxi
tested S65 , phone working now without any problem
Old 07-02-2005, 16:11   #14 (permalink)
H_C_K's Avatar
Member: 109224
hmm so I'm the first one who killed c65 maybe I've done sth wrong I will do it again and try to ressurect that phone
Old 07-02-2005, 23:52   #15 (permalink)
Member: 120932
Unhappy
Originally Posted by japunlock
tested on c66
Thank you for the information partner, here in my country it is used the versions 37 and 54, but I believe that they need the TEST POINT, BECAUSE it doesn't DETECT IT THE PC
STEP 5 in LG KG200 IMEI CHANGE ufuktakiadam LG 3 11-23-2009 15:30
1112 imei change by patch credits consume but imei is still that sairat Universalbox 0 07-14-2009 08:54
How to change bb5 imei change by universal box shmily Nokia Base Band 5 ( BB-5 ) 19 11-27-2008 08:58
step by step elsokary ARM9 BASED M62 / M62+ 0 03-08-2005 02:46
Page generated in 0.70016 seconds with 12 queries
