S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
07-17-2005, 23:47 | #48 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 57
Member: 53988 Status: Offline Thanks Meter: 4 | -------------------------------------------------------------------------------- I have Siemens EEPROM tool v3.15 cannot be start , it gives unexpected error. i tried it on win98 and winXP the same error. I have all these files msvbvm50.dll MSCOMM32.OCX COMCTL32.OCX comdlg32.ocx but i dont have mavbvm5.dll who can help to start this program.?? thanks in addvance |
07-18-2005, 11:59 | #49 (permalink) | |
Junior Member Join Date: Jul 2004 Location: Istanbul / Turkey Age: 46
Member: 74048 Status: Offline Thanks Meter: 1 | Quote:
If the program stay in "Factory Mode" doesnt matter. Click Freia Log , save the log after that , open Map Maker , open log , Save Map. Now it's important.... : Run Eprom Tool 3.15 Load (button left) , selecet map Click => buton middle of the program Select All (from Right) !!!!!!!!!!!!SAVE SELECTED!!!!!!!!!!!!! Dont click Save All button OverAll Success.... | |
07-18-2005, 15:02 | #50 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | my problem that the phone can connect using tp but when i try to enter sky it gives always error also the phone can't connect to the eeprom tool any solution thx |
07-18-2005, 18:06 | #52 (permalink) | |
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | Quote:
07-18-2005, 21:11 | #53 (permalink) |
Freak Poster Join Date: Apr 2004 Location: ilina Age: 44
Member: 62102 Status: Offline Thanks Meter: 167 | Hi Patric Today i made unlocking one CX65 v43 in Papua soft. I connect power on phone to C55 COM cable. Run EEPROM tools and press Init. Phone not detected in EEPROM tools. Solution for this problem is : Open data C55 connector and connect 10k resistor from Tx line to GND. It work for this problem /i have CX65 v16 with this problem too with unlocking in free soft - not comunicate - connect one resistor from Tx to GND and everything is OK Try .... |
07-19-2005, 11:38 | #54 (permalink) | |
nothing happen always the samething any other solution | |
07-19-2005, 22:23 | #55 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16943 Status: Offline Thanks Meter: 35 | hi patric try to put one zener diode of between 3.2 and 3.5 volts, in the cable conector you have cable to pins 2, 3 and 4, well, put the diode between pins 2 and 4, catode diode to pin 4. regards |
07-20-2005, 11:09 | #57 (permalink) |
No Life Poster Join Date: Feb 2003 Location: TelServisHalo,Loznica, Serbia Age: 53
Member: 21365 Status: Offline Thanks Meter: 92 | I don't understann... ...What U expect from EepromTool if mobile swiched ON? Phone MUST be swiched off, conect hem on cable(c55 cable), thab "Phone" choose "=x65", press "Init", and MUST go to "service mode". Cheers |
07-21-2005, 23:28 | #59 (permalink) |
Junior Member Join Date: Jul 2005 Age: 50
Member: 163253 Status: Offline Thanks Meter: 0 | Is it posible to unlock CX65 without TP? Iīm afraid i donīt understand and donīt have the knowledge to do this TP. Is there a "dumb guide" for this, or another solution without TP? Thanx |
07-21-2005, 23:32 | #60 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Shenzhen, China
Member: 7911 Status: Offline Thanks Meter: 7 | Not for V43 - all the secuity holes and backdoors that people used to use have been closed. But the testpoint method really isn't that hard, once you get the general idea. |
Siemens C65 v43 after testpoint keys not work | iki | S-Gold Based Phones | 9 | 09-20-2005 20:04 |
SST 6.61, problem witch unlock C65 v43 | AndRe DCF-gsm | SST-Dongle | 1 | 08-23-2005 16:26 |
Pls Halp to repair my c65 v43 full falsh erased | davidoffman | S-Gold Based Phones | 14 | 08-07-2005 20:51 |
free unlock C65 v43 | gregscg | Siemens-Benq RingTones and WallPapers | 1 | 07-14-2005 19:04 |
C65 V43 new PCB? Where is testpoint? | James_S | S-Gold Based Phones | 4 | 05-06-2005 00:22 |
