S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
06-09-2005, 20:07 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Žilina Age: 44
Member: 62102 Status: Offline Thanks Meter: 167 | Unlocking C65 v43 - full solution thanks all for this solution - i´m only translate and collecting files ..... I´m sucessfully unlocked C65 v43 with this solution. |
The Following 4 Users Say Thank You to pepik For This Useful Post: |
06-11-2005, 13:32 | #6 (permalink) |
Freak Poster Join Date: Sep 2002 Age: 38
Member: 15999 Status: Offline Thanks Meter: 0 | Hi, i used this solution, at "Enter Skey in phone" I turned on phone (without connected TP) and..: Checking entry values..... Test ServiceKey... Enter ServiceKey in phone... SKey enter ! Pause 1 second(s)... SecurityStatus: FactoryMode and nothing.. i tried one more time: Checking entry values..... Test ServiceKey... Enter ServiceKey in phone... No answer from phone ! Check com port number,cable,phone and MODE ! Now, phone doesn't turn on :/ What do I wrong? |
06-11-2005, 16:04 | #7 (permalink) | |
Junior Member Join Date: Jun 2003
Member: 32600 Status: Offline Thanks Meter: 0 | Quote:
Ive done all steps (post1194032), reading was ok, but when i "Enter Skey in phone " ive this: Checking entry values..... Test ServiceKey... Enter ServiceKey in phone... SKey enter ! Pause 1 second(s)... SecurityStatus: FactoryMode Prog stops,then i made next step, Freia log and VKD 3.0x , opened mapper.exe Load log - select log file from papua soft Save MAP – save map Then Siemens EEPROM tool.exe, loaded map file from mapper and my phone only bips !!! I think I miss the part in manual: BlockEEP76 writted. BlockEEP5008 writted. BlockEEP5009 writted. BlockEEP5077 writted. Blocks saved in phone.... I havent made flash and eeprom backup..... (all u can kick me). My phone is a C65 V41 in "beep mode" but I can go to test mode using SST when I try to read.... I ve now one C66 V32 and one C6V V15 Can I use those phones to make backups and restore C65??? Help me please !!! | |
06-11-2005, 17:40 | #8 (permalink) |
No Life Poster Join Date: May 2001 Location: Hungary Age: 55
Member: 4695 Status: Offline Thanks Meter: 15 | Hi friends! The very important, never use the "SAVE ALL" function and make full eeprom backup before write the unlock map! Look at the pictures! BR Keni |
06-11-2005, 22:22 | #10 (permalink) |
Member: 62102 Status: Offline Thanks Meter: 167 | Try this for repair wrong software or beep: http://forum.gsmhosting.com/vbb/showthread.php?t=212424 Thanks Mamut |
06-11-2005, 22:57 | #11 (permalink) | |
I cant find C65 fubu..... Regards | |
06-12-2005, 04:19 | #12 (permalink) |
Banned Join Date: Oct 2001 Location: JMB Age: 49
Member: 6919 Status: Offline Thanks Meter: 12 | Do not play with it if u dont know about it.. if u have doubts ..before entering the "enter skey in the phone." make the v-klay loader and make the full back up so in any case u can revive the phone with the org flash in it..it takes me to 5 min to make the fulll back up with the v-klay with high speed com. I did the same mistake for the first time..but manage to get the phone back to life with the help of a friend in this fourm. But now i make backup first and than do any thing further. br |
06-12-2005, 08:41 | #13 (permalink) | |
.... I ve made the Vklay *.VKD loader and freia log (I dont know if both are good logs), but as I said before papuas soft stop in: "SecurityStatus: FactoryMode" many times, so.... I made the log from that and I miss the part : Checking enter values ... BlockEEP76 writted. BlockEEP5008 writted. BlockEEP5009 writted. BlockEEP5077 writted. Blocks saved in phone.... I dunno if my log and loader r ok... and then I ve made the map from log, map from log and write eeprom using map values. Thats all I ve made. Now I ve an C65 "beep". SST can t read phone and can t repair it, V klay can read and write flash. I can t downgrade using WinSup. Question is: How to get rid of "beep" mode ??? Can I use an C66 or C6V to make backups ??? change C65 to C66 or C6V I know how important is the backup from phone, but now I ve made the mistake. I hope u or someone can help me, if u have the recipe maybe u can share it to all members. Best Regards | |
06-12-2005, 10:01 | #14 (permalink) | |
Freak Poster Join Date: Mar 2004 Age: 51
Member: 59411 Status: Offline Thanks Meter: 1 | Quote:
Check your log if it has correct digits! Check with eepromtool that you can access block 5008,5009,5077, 5121, 5122 and 5123. | |
06-12-2005, 19:27 | #15 (permalink) | |
I can access to blocks 5008,5009,5077, 5121, 5122 and 5123 in phone. I think my logs are ok. But I can t find where s the problem...... Some suggestion ??? | |
Siemens C65 v43 after testpoint keys not work | iki | S-Gold Based Phones | 9 | 09-20-2005 20:04 |
SST 6.61, problem witch unlock C65 v43 | AndRe DCF-gsm | SST-Dongle | 1 | 08-23-2005 16:26 |
Pls Halp to repair my c65 v43 full falsh erased | davidoffman | S-Gold Based Phones | 14 | 08-07-2005 20:51 |
free unlock C65 v43 | gregscg | Siemens-Benq RingTones and WallPapers | 1 | 07-14-2005 19:04 |
C65 V43 new PCB? Where is testpoint? | James_S | S-Gold Based Phones | 4 | 05-06-2005 00:22 |
