S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
12-08-2004, 20:00 | #16 (permalink) |
No Life Poster Join Date: Feb 2004 Location: PaKiStAn Age: 44
Member: 51639 Status: Offline Thanks Meter: 76 | |
12-25-2004, 10:10 | #17 (permalink) |
Junior Member Join Date: Nov 2004
Member: 92948 Status: Offline Thanks Meter: 0 | Hi guys, i had the same problem with my CX70 due to finger troubles at the EEPROM tool and pressing save all. I wasn't able to write back the blocks 5008, 5009, 5077, 5121, 5123 with the EEPROM tool - error 15.... And i didnt have a patched bootcore... After searching and searching in all my known forums I found a solution. You need following programs and files: 1. X65flasher-1054: this version is able to connect without the bootcore patched you can get it here: http://www.forum.siemensmania.cz/uti...?page=3&type=2 even i dont speek czech i was able to register there :-) 2. EEPROM tool 3. a backup of the EEPROM - best would be yours, but also another one from the same model should do (it could be that block 5009 makes troubles) 4. smelter: http://avkiev.siemens-club.ru/Siemen...er/Smelter.rar 1. start x65flasher min. version 1054 2. connect to the dead phone 3. press "read flash", takes a few minutes! 4. at the place where you saved the file in step 3., create a directory called EEPROM (needed for smelter and so on) 5. start EEPROM tool 6. load the "backup" EEPROM files into the the tool (right side load) 7. save the EEPROM blocks you need (e.g. 5008, 5009...) as file type *.bin in the EEPROM directory you created, choose the same name you choose at x65 flasher and add an underscore _ followed by the block number! e.g. cx70_5008. EEPROM tool saves the blocks now into 2 files: *.bid (a description for smelter) and *.bin (the block itself) 8. repeat step 7 for all EEPROM blocks you need 9. start smelter 10. open the backup you created with 3. 11. press "E" in the menu bar (EEPROM blocks) 12. choose the EEPROM block number you have to replace and click right with mouse, choose "load block from the file" - here it is important that you saved the EEPROM blocks in the directory "EEPROM" and with the correct name otherwise smelter won't find the file (in the error message you see how the file should look like) 13. repeat step 12 for every block you need to be replaced 14. now save the whole file with "save as" 15. start the x65flasher and connect to the phone 16. click write flash - takes again a few minutes your phone should work again (mine is working again) good luck guys! merry x-mas! andi |
12-26-2004, 00:54 | #18 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: Lagos Nigeria
Member: 61176 Status: Offline Sonork: 100.86572 Thanks Meter: 368 | Quote:
12-27-2004, 10:05 | #19 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Online Sonork: 12399830 Thanks Meter: 136 | Quote:
working with some changes thx | |
01-01-2005, 23:17 | #20 (permalink) | |
Junior Member Join Date: Dec 2004 Age: 44
Member: 100364 Status: Offline Thanks Meter: 0 | Quote:
My phone died (S65 Vodafone UK) when trying to write a MAP file using EEPROM tool 3.15. It failed on blocks 5008, 5009 and 5077. I thought I'd be able to get around it by loading all from phone, adding the MAP blocks, and writing all back, however this killed the phone. I did a full backup before this using Eeprom tool 3.0 Now the phone just beeps once when I try to turn on, and nothing happens. The x65flasher doesn't do anything at all when I try to connect. The only thing I can get to 'see' the phone for a moment is Eeprom tool 3.0. However if I try to write my backup file back to the phone, I just get a run time error. Any other suggestions? SST 5.31 never worked when I tried it for unlocking, and it still does the same thing - when I try turning the phone on, it says Starting Service Mode then never any more, same for all functions. Thanks! | |
01-03-2005, 21:36 | #21 (permalink) |
Junior Member Join Date: Aug 2004 Location: Sighisoara,Romania Age: 44
Member: 78454 Status: Offline Thanks Meter: 0 | i think is not a good ideea to say something bad about mr x.trust me he is really good and kind. if you have a question , for sure you ll get an answer from him.always he is trying to find a solution for you , but when is no sollution he is gonna tell buy a martech.doing this you ll not waste time you ll make money.one more thing ... i invest 50 % of all i get every mounth , but i m always nr 1 in my place. sorry for my english , i can speak but i have some problems in writing. |
The final solution for rpaired MTBOX | .::AssAnovic.:: | MT-BOX | 41 | 08-01-2009 15:33 |
The final solution to the problem of ZV60 Phone Freeze | king-gsm | Easy-Unlocker | 1 | 02-26-2009 13:53 |
The FINAL solution for those who have probs installing new setups TESTED!! | jawad8305 | HWK | 5 | 07-25-2007 06:56 |
to unlock your phone => the best solution TMS | patric | TOTAL MultiServer | 5 | 01-21-2007 09:51 |
X65 unlock The final solution is.. | ednacell | S-Gold Based Phones | 77 | 12-03-2004 02:23 |
