Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 08-20-2005, 05:07   #61 (permalink)
Member: 84390
Thanks Meter: 3
I'm using a Nokia BL-6C with 650mAh (from China, 2.5$), the bat life is 5 days (off during nights from 23 - 6AM, is that OK?
Old 08-20-2005, 07:43   #62 (permalink)
Member: 79973
hmm... As I know bl-6c is N-Gage QD battery and its 1070mAh
Old 08-21-2005, 16:17   #63 (permalink)
Member: 84390
Thanks Meter: 3
I don't know QD use wat bat, but I bought BL-6c kind for different Nokia, it's for small phone.
Old 08-22-2005, 21:31   #64 (permalink)
Member: 99408
1) i think that the fuse connecting the "-" pole might be damaged because the phone turns off when the battery is fully charged.it says V21 on the fuse. can i find it at regular electronics shops? is the fuse the reason why the phone turns off when fully charged?
2) and another problem: i used a Nokia 6100 3,6V 1300mAh battery pack without removing the nokia's IC instead connecting it directly to the siemens ic board. but it has very short life about 4-6 hours of standby and just a few minutes of talk time. what is wrong? should i try using SensorTools to calibrate it?
Old 08-26-2005, 18:00   #65 (permalink)
Member: 140362
Hi
I live in Belarus, Minsk.
Can anybody send 1000mah battery in my city? I hope that it will cost less than 6 eu.
insane[at]homenets.us
Thanks.
Old 08-26-2005, 22:34   #66 (permalink)
Member: 99408
ok...this is what i did: i replaced the non original IC board with the one from an original battery pack. now the phone doesn't turn off when fully charged. and i can leave it connected as long as i like.
as i mentioned i have Nokia 6100 3,6V 1300mAh battery pack, the big problem is that i believe that it is not fully charghing...the battery only lasts for 3 days of intensive use(30-40 min/day talking time, aprox 30 min/day mp3player). but i believe this battery should last longer(1300mAh).
1) how can i find out if the battery is fully charging(if i leave it for 12h connected to the charger, the phone indicates 95-96% capacity-is this normal?)?
2) what is the normal voltage of a fully charged, high capacity battery?
3) what is the normal voltage of a high capacity battery at which the phone should turn itself off ?
4) how do i backup my blk settings using SiemensSensorTools?
as soon as i will recharge the batt to the max i will post the voltage readings of the phone and the vlotage readings of a multimeter. i will also post the fully drained battery voltages.
I would so much like to find some clear info about SensorTools. Or about any other program that allows u to modify battery parameters from eeprom.
Old 02-21-2006, 18:18   #67 (permalink)
Member: 70080
Thanks Meter: 2
http://patch.oslik.ru/SL45_RU/galler...n/P1010537.JPG
Old 02-25-2006, 21:40   #68 (permalink)
Member: 70080
Thanks Meter: 2
http://www.hobbyforyou.ru/shop/?IDCa...Do=showProduct
Old 03-29-2006, 16:55   #69 (permalink)
Member: 91950
I found a BL-5C Battery, but it doesn't hold any longer than the old one, could some1 please post the blk backup used with this battery, or the original SL45 battery blk please?
Old 03-30-2006, 02:20   #70 (permalink)
Member: 137411
@WhACK0:
Someone has changed a BL-5C Battery to a SL45 battery. Look here: http://bbs.0110.cn/viewthread.php?ti...extra=page%3D1
SC box gets hot with 12v 1000 mah adapter emicabher Smart-Clip 10 06-10-2008 15:25
Enormous consumption of battery in SLIK56 kalac x4x, x5x Flashpatching 8 05-11-2005 21:40
I need .blk file for SL45 540 mah battery beshko x1x to x45/x50 2 10-06-2004 20:52
Settings 1000 mAh Li-pol battery for x55 difer E-Gold Based Phones 2 05-03-2004 00:22
1000 mAh blk for SL42 - SL54i! InCoMiNg x1x to x45/x50 1 06-20-2003 00:50
Page generated in 0.32389 seconds with 10 queries
