08-22-2005, 21:31 | #64 (permalink) |
Junior Member Join Date: Dec 2004 Age: 40
Member: 99408 Status: Offline Thanks Meter: 0 | 1) i think that the fuse connecting the "-" pole might be damaged because the phone turns off when the battery is fully charged.it says V21 on the fuse. can i find it at regular electronics shops? is the fuse the reason why the phone turns off when fully charged? 2) and another problem: i used a Nokia 6100 3,6V 1300mAh battery pack without removing the nokia's IC instead connecting it directly to the siemens ic board. but it has very short life about 4-6 hours of standby and just a few minutes of talk time. what is wrong? should i try using SensorTools to calibrate it? |
08-26-2005, 22:34 | #66 (permalink) |
Member: 99408 Status: Offline Thanks Meter: 0 | ok...this is what i did: i replaced the non original IC board with the one from an original battery pack. now the phone doesn't turn off when fully charged. and i can leave it connected as long as i like. as i mentioned i have Nokia 6100 3,6V 1300mAh battery pack, the big problem is that i believe that it is not fully charghing...the battery only lasts for 3 days of intensive use(30-40 min/day talking time, aprox 30 min/day mp3player). but i believe this battery should last longer(1300mAh). 1) how can i find out if the battery is fully charging(if i leave it for 12h connected to the charger, the phone indicates 95-96% capacity-is this normal?)? 2) what is the normal voltage of a fully charged, high capacity battery? 3) what is the normal voltage of a high capacity battery at which the phone should turn itself off ? 4) how do i backup my blk settings using SiemensSensorTools? as soon as i will recharge the batt to the max i will post the voltage readings of the phone and the vlotage readings of a multimeter. i will also post the fully drained battery voltages. I would so much like to find some clear info about SensorTools. Or about any other program that allows u to modify battery parameters from eeprom. |
03-29-2006, 16:55 | #69 (permalink) |
Junior Member Join Date: Nov 2004 Age: 42
Member: 91950 Status: Offline Thanks Meter: 0 | I found a BL-5C Battery, but it doesn't hold any longer than the old one, could some1 please post the blk backup used with this battery, or the original SL45 battery blk please? |
03-30-2006, 02:20 | #70 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 24
Member: 137411 Status: Offline Thanks Meter: 1 | @WhACK0: Someone has changed a BL-5C Battery to a SL45 battery. Look here: http://bbs.0110.cn/viewthread.php?ti...extra=page%3D1 |
SC box gets hot with 12v 1000 mah adapter | emicabher | Smart-Clip | 10 | 06-10-2008 15:25 |
Enormous consumption of battery in SLIK56 | kalac | x4x, x5x Flashpatching | 8 | 05-11-2005 21:40 |
I need .blk file for SL45 540 mah battery | beshko | x1x to x45/x50 | 2 | 10-06-2004 20:52 |
Settings 1000 mAh Li-pol battery for x55 | difer | E-Gold Based Phones | 2 | 05-03-2004 00:22 |
1000 mAh blk for SL42 - SL54i! | InCoMiNg | x1x to x45/x50 | 1 | 06-20-2003 00:50 |
