11-21-2004, 13:41 | #18 (permalink) |
Junior Member Join Date: Nov 2004 Location: Romania Age: 39
Member: 92384 Status: Offline Thanks Meter: 0 | Will a 1000mah Nokia 6100/6600 battery work? If i follow the steeps u've shown and modify a 100 mah nokia battery it will work? will a nokia 8210 1200mah liion battery work as well ? tnx |
01-04-2005, 20:22 | #20 (permalink) |
Insane Poster Join Date: Jan 2004 Location: Sarajevo,B&H Age: 46
Member: 50599 Status: Offline Thanks Meter: 0 | I bought the battery... It doesn't fit, it's too thight! Battery is a little bit thicker... I forgot to say that I have 540 mAh battery housing... |
01-04-2005, 22:19 | #21 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | That's no problem. Look in your housing.. there's a black piece of plastic in it that holds the Siemens Battery and the contact board (the piece of platine). I removed that plastic and break it in the upper 1/3. Then I used some tape to fix it and pressed the platine back to the rest (the 1/3 part) of this piece.... Difficult to explain but I hope you understand. |
01-05-2005, 14:30 | #22 (permalink) | |
Member: 50599 Status: Offline Thanks Meter: 0 | Quote:
01-08-2005, 20:39 | #24 (permalink) | |
01-18-2005, 07:05 | #28 (permalink) |
No Life Poster Join Date: May 2004
Member: 66040 Status: Offline Thanks Meter: 14 | @sl45vietnam, I used 750mAh batt (for nokia 8210) for my sl45. Do i have to use sensor tool to make it work better? I tried useing sensor tool 1.3, loaded 650mAh blk, but when i clicked WRITE PHONE, it says ERROR cannot undo BLOCK 67. Whats wrong? Also, when im charging, the battery % indicator reaches 198% but the charging time is about 1hour and a half, which is the same length of time as my old battery fully charges. |
01-18-2005, 15:32 | #29 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Vietnam Age: 49
Member: 84390 Status: Offline Thanks Meter: 3 | Error at BLOCK 67 is the block of battery, it make phone cannot turn on. You have to write your eeprom or full flash backup, or you can only write block ID 67 (you can use Smelter to extract this block and write it to phone). After use change values by SSL maybe the % indicator is not exactly. Use SST to optimize battery is so difficult, now I still don't know how to do it. I have to grape (fumble). |
02-11-2005, 22:05 | #30 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Russia inc. Age: 51
Member: 48199 Status: Offline Thanks Meter: 0 | Thanks 2 Red Fox I use Nokia BR-5C battery. If no play MP3 and turn off the phone at night discharging time about 4 days (instead of 2 days with standard 650mAh battery). http://www.abomin.nm.ru/images/nokia...ry_in_slik.jpg |
SC box gets hot with 12v 1000 mah adapter | emicabher | Smart-Clip | 10 | 06-10-2008 15:25 |
Enormous consumption of battery in SLIK56 | kalac | x4x, x5x Flashpatching | 8 | 05-11-2005 21:40 |
I need .blk file for SL45 540 mah battery | beshko | x1x to x45/x50 | 2 | 10-06-2004 20:52 |
Settings 1000 mAh Li-pol battery for x55 | difer | E-Gold Based Phones | 2 | 05-03-2004 00:22 |
1000 mAh blk for SL42 - SL54i! | InCoMiNg | x1x to x45/x50 | 1 | 06-20-2003 00:50 |
